It looks like a substantial leak.Check the dip sticks on both engine and trans. One of them has to be low and will tell you where to focus your attention. It looks more like trans fluid than engine to me. You may have a trans bearing failure giving you an early warning. I would try to figure out what the problem is before riding.I cleaned it up really well and after one ride, it all appears again.
Checked the transmission drain plug and it's good and tight.
The only thing I did to the bike recently was replace the starter. I did have to loosen the bolts to the drive belt cover, but can't imagine doing that is now causing this.
And if the primary is leaking by the starter, then the leak would be on the other side of the bike. I'll look more into it this evening.
Thanks! I think over the weekend I'll drain the tranny and see what's going on. It appears to only be leaking when the bike is in use, as last night I placed towels underneath it and this morning there was not so much as a drop of fluid showing on the towels. I wonder if one of those oil lines could be leaking. Oh well, hopefully this weekend's inspection will show something.It looks like a substantial leak.Check the dip sticks on both engine and trans. One of them has to be low and will tell you where to focus your attention. It looks more like trans fluid than engine to me. You may have a trans bearing failure giving you an early warning. I would try to figure out what the problem is before riding.
don't forget to check the breather hose on the transmission as well.Thanks! I think over the weekend I'll drain the tranny and see what's going on. It appears to only be leaking when the bike is in use, as last night I placed towels underneath it and this morning there was not so much as a drop of fluid showing on the towels. I wonder if one of those oil lines could be leaking. Oh well, hopefully this weekend's inspection will show something.
Cleaned it up, and was good to go.At this point I’m thinking the leak is from the transmission. Rode it daily for the last week and checked the motor oil level and the primary fluid level, and both had not lost one iota of fluid. I drained the transmission and added 20 ounces, then rode it the next day. Those dip sticks for the tranny are sure tricky to read as the fluid is hard to see on it, but it did seem to be a bit low.It looks like a substantial leak.Check the dip sticks on both engine and trans. One of them has to be low and will tell you where to focus your attention. It looks more like trans fluid than engine to me. You may have a trans bearing failure giving you an early warning. I would try to figure out what the problem is before riding.
Yeah, probably easy fix but I just dropped the bike off at Arlen Ness to have them fix it. When I chatted with the tech there, I was impressed that he took the time to explain to me how to do the repair myself. But it seems the older I get…I’m now 66… the less I want to work on stuff. Knowing me I’d end up spending countless hours cussing and screaming at it as I keep getting frustrated, and when all is done I’d probably fuck it up and make it worse.Output seal is leaking. Easy fix.
Good deal. They are a love hate relationship, but I wouldn't give mine up for the world.Yeah, probably easy fix but I just dropped the bike off at Arlen Ness to have them fix it. When I chatted with the tech there, I was impressed that he took the time to explain to me how to do the repair myself. But it seems the older I get…I’m now 66… the less I want to work on stuff. Knowing me I’d end up spending countless hours cussing and screaming at it as I keep getting frustrated, and when all is done I’d probably fuck it up and make it worse.
Within their diagnosis of the problem he also found that the exhaust bracket was broken. He said they can just weld it though.
At this point I’m thinking I should have never bought this bike, but maybe once this is all fixed, all will be good, and I can just enjoy the ride.
Can you tell me where you foiund the UV dye -- that would be some really usefull stuff to add to my toolboxFound within another thread discussing leaks that one can add a UV dye into the suspected fluid and it will glow at the point it's leaking. I just did that, and after riding 30 miles, here is the result.View attachment 120020
So, the leak is pretty obvious. Is that what they call the Inner access cover gasket?
Perhaps other seals and gaskets should get replaced while I'm in there?
That said though, I might just have the shop do it as I tend to have no luck working on stuff.
The one I bought that I ended up using in my transmission was from Amazon and is called "InterDynamics Certified Auto Pro Oil and Fuel System UV Dye Leak Detection". The other one I got which glowed orange instead of yellow I got from the local automotive parts store (Monument) and was called "AutoPro UV Dye for engine oil, transmission, power steering, Fuel system."Can you tell me where you foiund the UV dye -- that would be some really usefull stuff to add to my toolbox
Thanks, just added some to my amazon cart for next time I need it,The one I bought that I ended up using in my transmission was from Amazon and is called "InterDynamics Certified Auto Pro Oil and Fuel System UV Dye Leak Detection". The other one I got which glowed orange instead of yellow I got from the local automotive parts store (Monument) and was called "AutoPro UV Dye for engine oil, transmission, power steering, Fuel system."
