Rintintin
With the help of several of you gents, I recently recovered from the loose clutch hub nut problem. After completing that, the bike ran and shifted better than it ever has (I bought it June 2022 from 2nd owner. I rode it a couple of times after that and then one day after stopping for lunch it starting misfiring a little on the way home. I made it home fine and thought that was odd. The next time I took it out, it started and was doing fine until about a mile from the house it started sputtering like it was in and out of power then just stopped. It would not restart. I sat in a strangers driveway for about 5 minutes and it restarted than stalled out again and died. I started coasting/pushing it home. I restarted it about 3-4 minutes later and it ran the rest of the way home.
I followed the charging system tests from the manual section 7 and everything seemed to check out with the stator and VR. I performed the start-up test on the battery and it seemed to fail. It dropped to 4 when starting and then bounced back. I ordered a new Deka. (I called the Batteries Plus number on the old Duracell battery and discovered it was made in 2014! - picture is attached.)
I installed the new battery and the bike cranks SO much faster. It started fine as before and voltage did not drip much upon start. I let it warm up a few minutes and went for a ride. It started out just fine. Was running great, then it stalled and died again just like before about 1/4 mile from the house. I pushed it back for awhile. It restarted and sort of ran for a second then died. I pushed some more, and tried again and it started and kept running, and I made it home.
Here's some more info:
- the plugs look ok
- I took the air cleaner off and did not see anything odd inside the carb.
- when I turn on the ignition, the speedometer needle goes straight down, then up to 20 then back to 0
- when I start the bike a red light is on under the seat on one module and three lights on the side of another module come on. Of those three, a red one stays lit, a green and blue flicker. Pictures of this under-the-seat activity is attached.
- checked the AC output per the manual and with the motor running it is putting out 19 - 19.9
I am not sure where to look next - I would greatly appreciate some ideas
Thanks
Dave
2006 Mastiff
- the plugs look ok
Thanks
Dave
2006 Mastiff
