Matt300ZXT
I've taken this 02 Pitbull out a few times just around the neighborhood to get used to it and out on the highway 3 times for a stretch of about a mile at a time and a little bit around a Wal Mart parking lot, and while I'm still figuring out, I've discovered that even when the engine is fully warmed up, sometimes when I'm coming to a stop it still wants to stall out even with the clutch lever fully pulled in and will be a little tricky to restart unless I pull up on the enrichener tab. It doesn't do it every time, but it will from time to time. I can blip the throttle when holding the start button and it just doesn't seem to want to start/run unless the tab is pulled up.
Anywho, that aside, am I supposed to stink like exhaust fumes whenever I'm done riding? I had an old Datsun 280ZX that made you stink when you were driving because the design of the rear end would suck fumes into the cab if there was any sort of pressure difference in the rear end. And I'm guessing it was the seal around the tail lights that would be just enough to let fumes get sucked into the car so you'd always stink like exhaust after you drove it. Is the carb maybe in need of a good retune or something from running rich or what? Not sure if this is normal or not.
