Clutch said BYE
BIG HOUSE
DOG ONA DOG
Riding to the gentlemens club from Hooters last night I shift into 3rd gear and my clutch lever dosent return all the way. So I down shift same thing. Then it seemed like something in the trans was slipping(lugging). So I tried to slow down to pull over then no clutch. I limped home with no clutch:bang: Pulled apart the ball ramp assem every thing looks ok (including the shaft). So Gas and I reassembled but when we tried to adjust the clutch there was'nt enough adjustment so our first thought was the cable was stretched. We tried again loosened everything when we got back to the final adjustment it worked untill I pulled the lever then pop and the lever fell to the grip:bang: Any thoughts
BigDogBro1
Made in the USA
Hey House, Sorry to hear about your clutch problem. Glad you made it home okay.
Did the clutch cable lever hoop end break open or pull off the end of the pull cable at the lever?
slowrower
2007 Mastiff
I wonder if the clutch actuator slipped, this happened to me when re-assembling the clutch the actuator ball ramp (I took it apart to grease it while adjusting the clutch) during re-assembly it was not fully extended when I put the pulley cover back. The net net of it was the clutch rod would not extend enough to disengage the clutch fully .. just a thought.
A few other possibilities:
The cable lock in the actuator has come off or is not seated properly
The cable is stretched
The clutch diaphragm spring is bad (see your manual for the spec)
The cable lock (on the hand grip) is gone or broken
Clutch Plates are worn out (must replace the entire clutch pak)
I sure there are more suggestions. Hope you find and fix it!
BigDogBro1
Made in the USA
Well, I'm not experienced with these clutches but if the clutch won't disengage then my guess is that the spring diaphram plate has broken or the throwout bearing blew out. I'm assuming the ball/ramp actuator assembly works fine.
rwill20
Damn Brother,sorry about your Dog hope U get it worked out,wish I could be of more help. Sorry Bro.
MN K9
The cable was probably fraying....... then broke.
I thought a few guys on here have had troubles with their cables breaking.
Did you check that it's still intact after the lever went to the grip.
Yeah House called me on this so in the middle of working a double I got out of work for a few hours to go help him..
"Gas Man's Mobile Bike Repair"
Getting it all tore apart
Adjusting the clutch rod
But then when it was still "popped" it went like this
freeplay adjustment
But lever still way out
The clutch rod was seated properly but it still was way loose. Plus when you pulled it... it didn't move. The cable pull was ROCK hard!
We played with it some more and finally got it to adjust correctly. He pulled it and we got a loud metal "pop" out of the tranny area. It happened really fast and couldn't tell exactly. Then the lever went back to like the pic above or maybe even closer to the grip. And ROCK hard again.
I was thinking broken carrier and the clutch rod is pushing out on the carrier, releasing the diaphram spring tension on the clutch rod, also giving us that "pop" noise and with the lever even adjusted out... the slack can't be taken up cause its simply pulling the ball ramp and pushing the clutch rod out. Hence why you can't take the freeplay out.
If its not the carrier I think something else is loose. Either way as I told House last night, we would need to get into the clutch and see what we find. He's apprehensive doing this on a warrentied bike. The end result will be 1 of 3 things. Either he buys the parts and we fix it, dog is down maybe only a week. OR We tear into it, find out what's wrong, yes it will cost money and parts, put it back together and let warrenty take care of it and pay. OR Just take it in, and let warrenty do everything.
Slow... my guess to your questions
Nope... it is seated and still has its farrell
OUr first initial guess, could be but that doesn't explain the rock hard cable that doesn't pull
Could be and I hate diaphram springs for this... would prefer seperate coil springs. But would be a warrentied part.
Nope... good
Don't think so... this was a instant pop and still wouldn't show these signs I don't believe.
BDB1... ball ramp is fine
MN... I don't think its the cable... it still seems to work and will move the ball ramp
The answer lies in the clutch pack. But to do that, we will have to pull the outer primary and dig in. Its not a complicated setup. Its just the warrenty issue.
I think House is looking for more ideas to help him decide to dig in or warrenty up.
05chop
If you remove the inspection cover on the primary.Take a flash lite shine it at the clutch plates.You might have to rotate the clutch a little. Have some one pull the clutch in.Now look and see if the basket moves or if the plates separate.This should give you something:job:
Smart idea Chop :2thumbs:
MN K9
A dropped nut sounds painful!
Sounds like an easy fix. Can't hurt to try peek in there.
Chopper Dave
SIICK!!!
damn House...sorry to hear about your clutch....
Gas Man....you da man!!:up: :whoop: balling out the bike jack and tools for House.....cool shit!!:cheers:
House ...hope you get it taken care of....
BIG HOUSE
DOG ONA DOG
Gas....Mine did the exact same thing. The nut on the clutch basket had come loose.
You da man:2thumbs: After every dealership in Mi told me they could'nt even look at for a week I said piss on that and went in to see if the nut was loose and yuppers that was it. thanks guys
