Jeff Taylor
My headlight just went out I'm hoping it's just a bulb I can't get the ring off to check it the set screws on the bottom are junk
Sounds like an adjure bucket with the phastlock system. There should be a Nylon white rope in that slit you pull out. Grab a set of needle noseSo what do ya do with a headlight with no set screws. Mine just has a slot at the bottom, probably an inch wide.
Ahh!! That's what that is! Thank you!Sounds like an adjure bucket with the phastlock system. There should be a Nylon white rope in that slit you pull out. Grab a set of needle nose
Sent from my SM-G925P using Tapatalk
Okay then don't pull that rope out all the way! See if you can just back it out enough to where the light will moveMy bulb is fine, it's just crooked, and driving me a little nuts.
Try some double sided adhesive tape around the bulb where it contacts the bucket. That's what I did on my adjure to hold the bulb in placeMy bulb is fine, it's just crooked, and driving me a little nuts.
The adjure doesn't screw in like a standard light. One of the reasons I love their lights.Those headlight rings are tricky sometimes, once you pull it out make sure everything is nice and clean and a little wd40 on the white ring & life will be a lot easier when it comes to putting it back in place. Oh and patience lol don't force her. I dread taking the ring out of mine. Its ridiculous how tight the fit is.
Never had any issue with mine, takes about 10 minutes to R&R headlight. Also headlight stays straight without any adhesive to keep it in place. The Tejas has a set screw and what a pain in the ass it is, small set screw recessed up inside a larger hole, plus I can't see shit that small...even with my glasses.Those headlight rings are tricky sometimes, once you pull it out make sure everything is nice and clean and a little wd40 on the white ring & life will be a lot easier when it comes to putting it back in place. Oh and patience lol don't force her. I dread taking the ring out of mine. Its ridiculous how tight the fit is.
Maybe try a new alan wrench or even a metric alan wrench if you rounded them out. Maybe even a small torx screw driver, if you drill them out, sure as shit you're liable to screw up the threads
Put a day maker in and don't worry about itMy bulb is fine, it's just crooked, and driving me a little nuts.
So you were sneaking in some looks were ya?I didn't care for the wolf light until I saw it up close on Ker's bike. It's pretty damn sharp![]()
Yeah, I took a quick look. I was thinking, "it must be the injectors, no, maybe its the throttle body needs a cleaning, no maybe if I hit the run button. Just messin with ya, the 100 degree temps couldn't have anything to do with it. it is a good looking light setup.
I was trying to explain to him how the bike works, even though he has one just like it, after the 3rd time, I was starting to get a migraine. I kept telling him the key is on the other side, not the side he's pointing to
$50 is damn expensive?IF they weren't so damn expensive!
