Srodden
Any reason for smaller plug gap ? CuriousCORRECT.........
I also like a .035" gap.
ILearned that the hard way,stay away from Iridium plugs,hahaJust an F Y I for those that may not have known. Below is a section right out of the 2003 Service manual....Could lead to some of the electrical issues some bikes see from time to time.
Do not use spark plugs other than the specified Champion brand.
FROM 2003 SERVICE MANUAL:
SPARK PLUGS
CHAMPION SPARK PLUGS, used as original equipment in all BIG DOG motorcycles, utilize a patented semi-conductor resistor to substantially reduce radio frequency interference (RFI) created each time the spark jumps across the gap of the spark plug. This RFI can result in starting and drivability problems, loss of performance and can even cause the ignition system module to completely shut down.
It is extremely important to use Champion resistor-type plug to ensure that the onboard computer that is the basis of BIG DOG motorcycle’s ignition system, is protected from this RFI.
Do not rely on industry standard cross-referencing to find an alternative brand of spark plugs to replace your CHAMPION OEM’s with. The replacement plugs may not be of a resistor-type.
Use only CHAMPION RN12YC in S&S motors and RA8HC in TOTAL PERFORMANCE
(TP) motors. Spark plug gaps are both .040”
Oooo, the mentioned problem has nothing to do with how often you replace the plugs...I've had great luck with Ngk iridium plugs but then again I change them each season cheap piece of mind
I thought so to,until I swapped them for some Champions, what a difference, Scoot started to run crappy,i thought it was bad fuel,read up on a few threads to stay with the recommended brand,so I did all ,bike runs like a million bucks,iam convinced, lolI've had great luck with Ngk iridium plugs but then again I change them each season cheap piece of mind
You complete me!There's a reason why they recommend .040 and I'm sure its because they thought that would be a good number to pull outta their ass, and with that said at $1.50 ea, or a total of $3 for 2, I change them yearly
As a plug ages, and the metal of both the tip and hook erode, the gap will tend to widen; therefore experienced mechanics often set the gap on new plugs at the engine manufacturer's minimum recommended gap, rather than in the center of the specified acceptable range, to ensure longer life between plug changes. On the other hand, since a larger gap gives a "hotter" or "fatter" spark and more reliable ignition of the fuel-air mixture, and since a new plug with sharp edges on the center electrode will spark more reliably than an older, eroded plug, experienced mechanics also realise that the maximum gap specified by the engine manufacturer is the largest which will spark reliably even with old plugs and will in fact be a bit narrower than necessary to ensure sparking with new plugs; therefore, it is possible to set the plugs to an extremely wide gap for more reliable ignition in high performance applications, at the cost of having to replace or re-gap the plugs much more frequently, as soon as the tip begins to erode.
