Threwithu
So let me preface this with the fact that I have had starting issues in the past due to the power cable bolt to the starter loosening over time with road vibration causing the bike to not start even on a full battery. the bolt and power cable becoming extremely hot to the point of burning the rubber boot
Yesterday not having ridden for a few days decided to take the bike out for a small spin. The weather was about 68 degrees so when I took it off the battery tender and rolled out of the garage, the bike was just not starting and loosing cranking amps. Decided to give it a jump from a 12 volt non runningcar battery and it started right up. Drove it about 2 miles when I noticed smoke coming from the front of the bike. I pulled over quickly into a gas station (wrong place to pull over with possible fire issues) and turned bike off. Smoke become worse and a small fire started in the front right under the voltage regulator. Got some water and put it out. Noticed that the wire coming out of the voltage regulator and going back to the battery/EHC area had burned completely through the wire/flame retardant cover and had started right at the Voltage regulator wire opening, which was now bear and touching the frame. Moved it from the frame and was able to start the bike and get it the 2 miles home. Once home I noticed the lightly loose power bolt to the starter which explain the difficulty in starting, but cant figure out why the wire go so hot to burn through. Any and all ideas appreciated and welcome
