LoWeLL216
Yeah I got some of the dry silicone. Do I just spray the whole belt?Sounds like belt chirp....try a little grease on the side of the belt and see if it disappears.
G
Sent from my SM-N920T using Tapatalk
G
Spray the inside of the belt as much of it as you can, place can in pouch and repeat at every stop...Yeah I got some of the dry silicone. Do I just spray the whole belt?
Won't that stuff fly all over the wheel if applied to much?Spray the inside of the belt as much of it as you can.
That saved a lot of coin![]()
It's a glorious day. Filed some knicks off the threads and she went back in.
I use the rubber handle of my hammer in the notches to tighten or loosen that cover, Yeah Yeah, I know I'm the hammer n chisel guy
some times ya gots to use the soft sideLost yer bet on that one, didn't ya?? Like a dose of the clap. I'm back !!I call bullshit..![]()
You don't need much and it dries clear. I never had a problem with it.Won't that stuff fly all over the wheel if applied to much?
if ya dont wanna make a spray mess, try rubbing a bar of plain soap on just the EDGES (inside and outside) of the belt. The soap will quell the squeek and not sling off. Wont last too long but allows you to pinpoint your problem. Jm .02Yeah I got some of the dry silicone. Do I just spray the whole belt?
That works too but buy a BIG bar of soap....if ya dont wanna make a spray mess, try rubbing a bar of plain soap on just the EDGES (inside and outside) of the belt. The soap will quell the squeek and not sling off. Wont last too long but allows you to pinpoint your problem. Jm .02
DOH !!!!I would consider a "like" a post... You're still in the denial stage..
I'm only up to step 3 in the program !!
Step 3 ??DOH !!!!I'm only up to step 3 in the program !!
You're still knockin on the door of the first step..
but don't worry, I'm right there beside ya..
I run 36 pounds, never an issue..Used silicone. Seems to mostly have taken care of it. Still some squeal, but mostly gone. Still seems to mostly happen on turns.
Next stupid question - how squirrelly (I know - real technical term) are your bikes on turns? This is my first bike with a rear tire this big. It almost feels/sounds like the tire is under inflated. Don't think it is...
if it is squirrelly, might want to give your rear bearings an inspection and then the swing-arm shaft.
, I was thinking the same thing.Slow down in the turns,Used silicone. Seems to mostly have taken care of it. Still some squeal, but mostly gone. Still seems to mostly happen on turns.
Looks like you got a sponsor chubs!Step 3 ??You're still knockin on the door of the first step..
