Took the primary cover off took the plates off and they looked find. The nut is tight and no metal shavings. I'm going to put everything back together and fill the primary oil back up. I'm using LUCAS 20 50 HP motorcycle.What did you find out about your locked up clutch?
I did roll the bike while in gear and the discs move as well. The clutch isn't locked up so I'm hoping it's just the clutch adjustment.So is the clutch locked up yet?
Did you try to roll the bike while in gear while the primary was off and clutch pulled in?
When you pull the clutch lever, do you see the clutch pack disc move?
Dito. HD here too.yep adjust the clutch..as long as the plates arnt worn out... & I use HD primary fluid..
x 2amsoil
