New pics
I could barely squeeze a piece of paper in, it rub both sides, to close for me, I just made it so it does t touch the .008203 feeler
Sent from my HTC Desire 610 using Tapatalk
The reflectors come off really easy, was going to remove them today, but one of the allen heads stripped out SOB. So I will wait
One other thing regarding the air cleaner, found the bracket, it's broken, that's why it's mounted like that. I noticed one of the ears on the carb was broken too. Couple more things to fix up on it. But I will get it taken care of. Thank you for pointing it out. Lots of knowledge on here when it comes to these bikes, glad to be a part of the community and learn.
I would check the carb housing to make sure there is no damage. Also if one of the ears is cracked you may lose the seal causing a seal leak. Not sure how bad it is without pics
The bracket should bolt into the motor and will have breather bolts. Hollow bolts with a hole in them that allows the motor to breath. If you have any ?'s feel free to ask
05+ dogs have the one way check valve. They don't breath through those holes like the 04 does. He would have a mess on his hands already if they did. No need for hollow/banjo bolts on that model
It's the very edge of the ear, no crack in the housing from what I can see, I will post up some pics later.
The bracket mounts into the motor, and has holes where the breather mounts so you can turn it in any direction you desire I am guessing. As far as the hollow bolts I am not sure on that part.
How is the bracket broke? I have aftermarket filters on both bikes and have the same setup on the pitbull. Those brackets are pretty durable
