The manual states 1/4 to 1/2 inch deflection at 10lbs force with riders weight for belt tension. Myself personally run mine about 1/2 inch deflection without rider on bike. Just make sure after setting belt tension to rotate your tire clockwise and see that the belt is centered on the rear pully.
I run mine a little looser. I had my rear pulley done by SuperMax about 3 years ago and they told me that most of these belts are running to tight. I've had no problems with the looser belt. Anyway that's what I am doing.
I'm also running my scoots a bit loose 1/2" deflection, have had no problems...
I had to tighten mine up. At 1/2 the wheel would shift around too much when accelerating or on decel.
X2, How in the hell would you adjust it while sitting on itThe manual states 1/4 to 1/2 inch deflection at 10lbs force with riders weight for belt tension. Myself personally run mine about 1/2 inch deflection without rider on bike. Just make sure after setting belt tension to rotate your tire clockwise and see that the belt is centered on the rear pully.
Tell 'em Ker!!! (with a hammer & chisel)X2, How in the hell would you adjust it while sitting on it:lol:
No. This is a standard hex head jam screwWas going to tighten my loose belt and the nut was all crushed in and deformed.
Is this a standard part or a Big Dog Specific nut?
Freakin Wanker:lol:Tell 'em Ker!!! (with a hammer & chisel)some ignorant brainless ppl out there!!! :bang:
:roll::roll::roll::roll:
Start with simple. Rub a bar of soap on both inner and outer edges of the belt. If it stops, you have the dreaded belt squeek......lol. If thats the case its just a matter or doin an alignment on your belt, OR you may have a worn pulley? Do some site searching on belt squeek.I just ran a crossed a problem with mine as well I was riding it and I started to hear a squeaking sound when I got home I was pushing the bike forward and noticed it was my belt squeaking like it all of a sudden became too tight. What would cause that
Thanks man.. I will try itStart with simple. Rub a bar of soap on both inner and outer edges of the belt. If it stops, you have the dreaded belt squeek......lol. If thats the case its just a matter or doin an alignment on your belt, OR you may have a worn pulley? Do some site searching on belt squeek.
Also it's not as much of a squeak as it is a noisy rub or something hard to explain but I will try to soapThanks man.. I will try it
Silicone spray worked great..Thanks allStart with simple. Rub a bar of soap on both inner and outer edges of the belt. If it stops, you have the dreaded belt squeek......lol. If thats the case its just a matter or doin an alignment on your belt, OR you may have a worn pulley? Do some site searching on belt squeek.
