xxcarpxx
I've gotten away from the POS Lightning Start battery, and installed a new Duracell.. I have started thinking I was having a starter problem.. Installed the Duracell and fired the Dog up no problem.(the Lightning Start would drag and take a extra charge to fire up) I have read the How To on Checking Charging System.. But with limited knowledge, I'm not sure if my readings are considered.. My thinking is I have a bad Voltage Regulator and also a Ground drain on the battery.. Here are my Voltage Meter readings..
BATTERY
Post to Post(idle)= 13.30vdc
Post to Post(rev) =14.02vdc
STATOR
Choke On= 32.vac
Choke Off=16.vac
Ohm= OL
VOLTAGE REGULATOR
Pin to Pin=2.42m Ohm
Pin to Pin=2.39m Ohm
Diode= OL..OL (both directions)
NEGATIVE VOLTAGE DROP
Post-Ground Lead= .015vdc
Post-Breaker Lead=12.76vdc
Post-Charger Lead=.0
Let me know what you think.. if more testing get is needed, please explain.. so I can correctly provide the info needed..
Thanks..
BATTERY
STATOR
Choke On= 32.vac
Choke Off=16.vac
Ohm= OL
VOLTAGE REGULATOR
Thanks..
