type and size of battery
bigchazz
Hello all....don't want to gat a battery that doesn't fit, had a friend that did exactly that. I have a 2005 Pitbull, anyone have the dimensions for the correct battery? I know its a tight fit, also what's the best (your opinion) and CCA, bigger = better ?? Thanks for any advice.
chubs
10 different people will name 10 different brands. I put a Harley battery in my pit bill and have an Interstate in the sporty. both fire right up. The dog started 7 times in a row today, while I was working on the solenoid wire that keeps working loose. My opinion is go with what you can afford, (over 315 cca) just my opinion
Well that sux, I don't like the idea that they don't put a date on these AGM's, you don't know if its a year or 2 old when you get them, however getting one that don't pass a load test and it takes 20 seconds to test is rediculous. I just got a load tester myself to test the battery's, I purchased a Harley battery 4 months ago and I don't think it has the nuts. So I just purchased a Duracell locally so if it takes a dump I can take it back, but it has a 2 year warranty no prorate.
By the way, those are nice counter tops you have in your garage, are you trying to keep up with Trainguy?
