Analog
[Guys, I have a 08 K-9, Year and half ago I had gas seep out of my gas cap and totally ruin my tank paint. Tank was removed, totally redone body filler and all. All contaminated material was removed! Spent over 3K on a custom paint job, new paint saver ring, gasket, and gas cap was installed. Now I'm having problems with the paint starting to blister at the paint saver ring.
I never fill my tank all the way up, shove the gas nozzle all the way in and when it clicks of that’s it! Gas is at least 3 to 4 inches away from the neck. All I can figure is the gas fumes are attacking the paint. Bike is kept inside a garage, it's cool, so it's not like it's baking in the sun building pressure. Tank is coming back off this weekend and going back down to the painter to get fixed. I don't want this happening again! I'm to the point of having a custom made one piece billet aluminum gas cap with a vent hole drilled though the center, tapped for 1/4 pipe and getting Aeroquip fittings and stainless steel 1/4" braded hose and venting right to the road to get the fumes away from the tank.
Has anyone else had this problem of fumes blistering your paint and if so what was your fix??
Thanks
Thanks
