Something broken - steering (neck)
francoblay1
The Spaniard
pknowles
RETIRED
That's fucked up. I believe I would get that fixed. If it's ok broken they would have put a broken one end at the factory Just my opinion.
Hey bro....replace your neck cups. They hold the bearings and races. I found one on the Pitbull that looked like that. Scared the shit outta me...Derick n Donna!!!
Diesel Dan
better fix that shit Franco:flag:.............that's not good..........and quit aiming for all the fucking potholes in the road:lol::lol:...LOL.......You crazy bastard.......hahahahaha....get that fixed.........The next pothole you hit might stress that enough to break it in half and there go's your bearings dude:eek:.....You could crash bad:down::down:....... Fix that for sure brother:2thumbs:
BadDawg Bill
That cup crack could cause the bearings to lock up or fall out and dump your butt on the pavement. It's a simple fix and you would be smart to fix it a/s/a/p.
francoblay1
The Spaniard
Well... I am fucked then...
Could I just weld the (two) cracks? It seems to me it is a very big job to take the whole front end apart!!! It would cost me around 1,000 Euros, the HD mechanic nearest me charges 75 Euros/hour + tax for labor :bang:
It looks like I will have to put the Dog to sleep. :angry:
Diesel Dan
to much prep work to repair that correctly with welding bro........you would have to grind out that crack a little bit,find the correct welding rod or wire to repair it,its right next to the frame,might burn all the paint,just to much hassle:(..........we need you out there shooting Tango"s:lol:,not laying down in a ditch.....sucks dude,but that should be repaired correctly man...........that's a big safety issue:).........
BadDawg Bill
It's not a big deal. Jack the front up so the front wheel is about 5" off the floor. Take off the top nut, the tube bolts then take off the top tree. (better to have help here to hold the front end. you can tap the tree with a rubber mallet to get it off)
Slide the whole front end down until the neck stem comes out and clears the neck. You can disconnect the brake line so you can wheel the front end and stand it up. You will also want to have a thick blanket on your tank to place your bars and top tree when they come off.
Take a punch and hammer and tap out the lower cup. Take a new cup and seat it as far as you can and then use a 2x4 and hammer to seat it in all the way. (a little grease in the neck helps.) Put in a new bearing well greased and slide the tubes/neck stem back up and in. Put the top end back together and hook up and bleed your brake.
All in all 2 guys working on it should take you about 2 hrs. Maybe 3 if this is your first time with beer breaks.
Your mechanic if he knows what he is doing should charge you for just 2 hrs time and about $30 parts for a new cup and bearing. I'd also replace the top bearing as well.
Good luck
Junk. Do not ride. Find one big rawhide mallet and hammer a new set in. Cold pounding is the only way to save the paint job. You heat the neck, well that's out of the question.
BadDawg Bill
Bdog, where is the bearing preload? You had everything I was about to say. Finish it.
You just did buddy! :D
...slowly crank the neck bolt down until the slop is gone...give it an extra 1/8 turn...tighten everything up. Go riding.
francoblay1
The Spaniard
Awesome, thanks Bill & Sven, that's the "How-To" I was looking for :2thumbs:
Now I need to find the right parts...
francoblay1
The Spaniard
Yup, I am on it.... I will be back at home in two weeks time.... hopefully the parts will arrive at the same time too!
I have sent a couple emails... just waiting for replies... :up:
Easy fix Franco. Pull ur front end, drive out the old cups and drive in the new ones. Use a block of wood and a dead blow hammer....easy peasy. Better put in new races n bearings while your there.
