LED Bulb from Wild Steeds
BFB
Bad dog, no bisquit
Just put the new LED bulb in this weekend. Plug an play and much better than the stock bulb. Nice bright white. If cagars can't see this thing coming, even during the day, their blind. Also bought the oil pressure relocation kit. Easy install, looks and works great. As always, quick and friendly service from Wild Steed. :2thumbs:
Yea I saw this and wanted to see some positive reviews before dropping the 60 bones.
Any comparison to the HID Kit? I got one of those sitting in a box but if the LED is better I'll just hock on ebay and go with LED easier and better?
sean92591
did you have to buy the harness controller for the big dog EHC or PDM. does one need to buy the harness if you have the wires plus kit?
pics please
sean92591
I just installed this bulb tonight and it is killer! I hope to never ever ever have to take apart that awful headlight bezel. this bulb just saved me from buying the $500 adjure sunset strip led complete headlight assembly.
KnotSo
Admin
I purchased this light from Curtis (Wild Steed Works) along with a few other must haves and it was delivered to me in two days, ultra fast service. Will install it next week and then I will be on a ride-about for a few days. I will do a ride report on this light when I get back.
I have used the stock light then installed the HID light and used that for a few years. I off road and LED can be better than HID on some fast night runs, so want to try the LED on the scoot. Like many of you I do ride a lot at night and many times it is raining.
The reports from current users sound like this may be the best light for our Hounds.
KnotSo
Admin
larger image
<NOSCRIPT></NOSCRIPT><!--eof Main Product Image--><!--bof Product Name-->
LED REPLACES H4 BULB
<!--eof Product Name--><!--bof Product Price block -->
<!--eof Product Price block --><!--bof free ship icon --><!--eof free ship icon --><!--bof Product description -->Get rid of that legacy H4 Headlight bulb and step into the future with LED lighting
Price is for a single bulb (1)
White-Low beam
Blue- Hi beam
Black-Ground
Comes with different mounting rings to fit most motorcycles
No relay required
Output Power: 18W @ low beam 25W @ high beam Input
Voltage: DC10V-DC32V
Lumens: 1400LM for Low beam 1800LM for High Beam
Life-Span: more than 30000hrs
Color Temp.: 5000k
Construction: Die cast aluminum
Cooling: Aluminum heatsink
DOT compliant
Energy star compliant
80% energy savings over halogen bulb
http://www.wildsteedworx.com/index.php?main_page=product_info&cPath=65_68_173_82_100&products_id=1260
What part of, :worthless: are people NOW understanding?
heh, Hope this helps you NOW understand?
wolfen
I put the whole unit on my chopper , I think it was 235.61. I love it , gives off much more light than stock. The only thing it came wired backwards. I have to swap the leads.
wolfen is online now Add to wolfen's Reputation Report Post Edit/Delete Message Reply With Quote Multi-Quote This Message Quick reply to this message
wolfen
View Public Profile
Send a private message to wolfen
Send email to wolfen
Find More Posts by wolfen
Add wolfen to Your Contacts
KnotSo
Admin
This is due to the nature of the BDM EHC and how it handles low current scenarios. The directions say you will need to change the high beam and low beam wires in your h4 plug. Simple enough.
wolfen
View Public Profile
Add wolfen to Your Contacts[/QUOTE]
Splitlog
FULL PICTURE WITH ??
I have two customers running the light with wire plus and they are not using the harness.
Ok, I obtained this LED from another member here that has a EHC.
What harness do I NOT need when using with my wire plus?
can i just cut off the two items my pen is pointing at? Advice before I butcher this item. Its going in a Wolf headlight so I would like to eliminate anything not needed do to small amount of room and no screws to bolt thes to items down as the instruction say to do.
Thanks in advance.
