snypr
So the original battery died. Took it out put in a new one. Turn the key on (no speedo light only headlight) pressed the Run button and turned the key off. Waited 30 seconds and turned key on. Speedo lit up with needle stuck straight up. Pressed run and pump didn't kick on. Turned key off and speedo back light and bike running lights stayed on.
Un hooked battery, waited 30 minutes, hooked it back up, reset procedures again with the same result. WTF?:angry:
