The threads are very fine, and easy to cross thread when putting back togetherHummmmm it sounds like we have a different set up?
Yes to the little screws underneath.... but then I dont have to spin anything.... I just pull it out with a suction-cup.
From the picture Franco you have a different headlight than stock.No threads whatsoever on mine.... I will be home this Friday... I will take pics.
The screws underneath are the only thing that holds the optic/ring in place.
That could be right too! remember I did ask you an O-Ring for it long time ago?From the picture Franco you have a different headlight than stock.
So the trim ring is definitely threaded?Don't give up just yet. Like was said above. Latex gloves and a firm grip should get it. I had the same problem with mine 2 years ago when I changed the bulb out. Tried and tried and it finally came loose.
Put your thumbs on the ring and your fingers on the outside of the bucket and squeeze and twist your thumbs, work around it.Got all the set screws out but there's no way to spin that trim ring off. I marked it with a piece of black tape. I had some latex gloves on and still no way it would spin off.
just don't use a hammer and chisel:roll::loony:Or stand behind the light and you can use all your fingers to pull in and twist at the same time. It worked on mine.
