Probably, I just like to have everything I need before I start tearing stuff apart. Ill check drag specialties Thanksisnt there a number stamped on the side of the bearing??
Don't ride that scoot like that. If you can't fix it then send it to us and we will fix it for you. We just did one for another member that had a similar issue.If anyone is still paying attention.... tried to tighten the bracket...screw broke off in the fork...fml...tried to drill it out a little but i got scared to drill too deep...so i put a piece of rubber tape between the bracket and the fork and tightened the one screw...used locktight...i realize this needs to be fixed right but i figured ill take it easy on the front brake and check it often until i figure out what to do..hopefully i dont need a new fork...also any tips on refilling the brake line? Steps to refill and bleed manually? In the past i have filled it..let it sit overnight to help the air naturally rise out and then bled what seems like forever...is there a faster way without buying the vacuum? Sorry i have so.many questions i will pay it back with answers as i learn and as i can thanks..
The bearings classification is 12/16" or 3/4" for front. Rear is 16 or 16/16" as in 1".Still a little confused. Going off Ray's thread is the front 6204 2RS -12 or 6205 -16RS? I ones i keep finding are 6204RS Sealed Bearing 20x47x14 Ball Bearings 6204RS. Are front and rear yhe same?
