OK, to start with I am compairing "Skully" to my two previous BD's, this bike has allways rode like a dream, with very little vibration and no chatter under take off compaired to my other two bikes..
so here is the story, please keep in mind this is over about two months time;
1. had the rear tire changed prior to the road trip we took several weeks back. about 1200-1500 mile trip.
2. on the the way home i started to get a vibration, thought it was the rear tire out of balance.
3. had it check, could not find any problem, even thought there is some type of compound being thrown up on the trans from the front belt pully. it is thick like grease, it has what looks like alum sparkle in it. there is nothing thrown on the rear wheel or pully. had belt adjusted. belt look in good shape.
4.vibration and chatter under load is getting worse, had it checked again. still can not find any problem. again compound in on trans.
5. this past Sat we rode about 200 miles, compound again is on trans. we were cruiseing at 80-90 on the interstate, the right side bar vibrates so much it puts my hand to sleep. at 55 in 5th gear the bike chattered so badly when hitting the throttle to pass, i thought the pully was coming off. once you level off, the chatter and vibation decreases but is still really bad.
GUYS, PLEASE DON'T HIGH-JACK THIS TREAD, I REALLY NEED SOME GOOD HELP WITH THIS.
DAVE
DAVE
hey skully, not meaning to sound like i'm making lite of the situation, but sometimes you end up with a smart-assed tech that thinks it would be funny to put something in the tire and see how long it takes someone to figure out what the problem is. might not be a bad idea to at least have the tire pulled and checked. good luck!!!!!!!!!!!!!!:2thumbs:
