smartinez1984
Still trying to get used to my new 08 Mastiff - from the ride on that big, fat, monster 300 tire in the back
to living without a gas gauge (bike is not EFI). I've taken it out for about 3 rides so far and I filled it up before the 2nd ride. I reset the odometer at that time and rode for about 40'ish miles.
Took it out again this past weekend and was at about 90 miles when the bike started to sputter. I clutched the bike, throttled a few times, and it sputtered a few times, and then seemed ok. Took off again and about a minute later it started to sputter then turn off.
I pulled over, switched to reserve, pumped the throttle a couple of times, started the bike, and off we went.
I pulled over at the nearest gas station (I was at about 100 miles here) and filled it up. The tank filled up with 2.5 gallons so I'm thinking I wasn't running on empty when the initial sputter occurred.
I'm thinking I had a bad batch of fuel the last time I filled - I couldn't have been out of gas, could I?
What type of mileage do these bikes get?
Thanks!
-Samson
Thanks!
-Samson
you should go in the introductions and introduce yourself...then pin the map.....and after that ....lets see some pic's of your scoot!
