RubWhores latest inprovements width pitchers
RubWhore
Asshole Extraordinaire
So I got tired of looking at all the K9`s running around that all got the same stuff as mine so I started changin stuff so here it is a totally redesined seat from Sterling that sinks you into the bike like a softail should,made me a nue shift rod,drilled out my mirrors,mounted me a set of wheels from a Bulldog which changed my front wheel to a 120 insted of a 90 or 2.15 rim width to 3.5inch width to inprove handlin and have been studyin about mountin this mastiff tank
The Brand R Nue Seat that Sterling who I think is reely Danny Gray sent me
The new shift linkage
The Mirrors after I drilled em out
The Mastiff tank I`m studyin about mounting
Another view of the tank
The 120 or Prosport wheel on the Dragon Springer
Another view of the wider rim
I got me a nue fender from Kustomwerks do to the wider rim and had painted it width rustoleum right before I took these pitchers and I didn`t want to get no fingerprints on it cause it was still wet but I will have it all put together and post the rest of the pitchers tommorow nite
Brew
It's looking pretty cool Rub, can't wait to see the finished product. How do you like the tank?:2thumbs:
RubWhore
I dont no yet I had to paint my K9 tank cause I rode this nakid harlet around on my tank at the last party I went to and she had her back all full of metal studs and put all kinds of up and down scratches on it but I think I`m gonna mount it after I go to Panama the front wheel idea is the best one that I comed up with since puttin the springer on though...I put new Avon tires on two but I figured everybody seed Eric`s so there wasnt no need to post pitchers of em
wibsdogg
Prez of M.C.O.B.D.B.
I can't belive your messin with the "E-bay Dragon" (i named it for you) but if it could be any finer than it is now I know you'll pull it off! Holler if I can help! I'd love to be able to claim a little credit even if its just sandin a fender! See you Thursday nite at Hooters in Panama unless you holler before!
I like it and especially the bigger tire in front. I want to put the wider tire on my Chopper too. I think it will track way better like my Mastiff did.
What are you doing with the rear fender?
RubWhore
Sounds good to me I gotta work Wensday thru Friday all over the Panhandle but will be in Panama at nite so we will get together
Ray right now I just pulled the rear fender and side covers to repaint cause I did a color change as I went from Black with gold metal flake to Black Pearl but I got one of them rear fenders from the Thunder Mountain liguidation thats got the Liscene plate sunk in it and I want to figure out how to cut a tail that raps the rear fender under the liscene plate the seat reely helped though cause I couldnt hold on when I gassed on it other than by rapping my foot in brake pedal and its got them gell inserts front and rear so its a lot more comfortable to,after I get all the tins figured out I been studyin with Ed on how we are gonna put the final paint job on got some reel good thoughts for it
Daddycool
what are you gonna do about the fuel petcock way up high on the mastiff tank? Looks like you will lose a lot of capacity.
RubWhore
I`m gonna have to relocate it and the crossover the petcock is gonna go on the oposite side and on a mastiff tank the crossover is in the front so I gotta move it as well... I got it all put together tonite and took it for a Virgin test run and what a differance ride and handling was vastly inproved ......ride hieght changed by about 3/4 of an inch so I slided my rockers to compinsate,fender is a little crooked but I can fix that with proper spacing cause all I had was whashers
funny thing is that you dont reely notice the wheel is that much bigger lesson you are studyin about it but here`s pitchers the low profile tire reely sets off the springer to
The space between the fender and the wheel is about a half an inch but the camera makes it look bigger
I got the wheels from a fellow forum member and the fender from kustomworks total cost of the upgrade was about 900 bucks which included both wheels rotors and a pulley a new fender oh and a can of spray paint from Walmart
BadBrad
2005 Pitbull
Lookin' good Rub. What kind of paint schemes are you thinking about once you get the bike ready for Ed?
RubWhore
Thank you I still got change a couple of things rode so good I blowed up the trany though.....lost all gears but 2nd up to 5th tored it apart and a bearing had went and ate half the trapdoor oil was kinda cool with all the aluminum floating in it kinda looked like red metal flake but we will be back ridin this week as I stole the trany parts from my new secret build and built up the trap door and mildreated it
