BadBrad
2005 Pitbull
It makes sense to do the leak down test before breaking into it. I hate to take for granted that I could break it apart and the problem be so obvious when it might be something that's not quite as visible to the naked eye. I may take it to have that done. I lost my compressor along with all my "toys and tools" in a barn fire back in January. I do have 12 point sockets though. That along with allen wrenches and a torque wrench looks like all I'll need for this job. I will have to get the rings compressed to get them back into the cylinder. No need to break it down without putting new rings in, even if that's not the problem for loss of compression. Anything else you guys might do while you're in there?
The two pics are from the inside of the rocker box. The first pic shows where a screw should be. The second pic shows where it has lodged beside the exhaust valve spring, keeping the valve open, eliminating compression and the ability to pull fuel into the cylinder. I'm not sure if I should just pry it out or pull the rocker box to get a better grip on it. Until I pulled the tank, I didn't see it last night when I pulled the Rocker box lid off. That valve is under the frame and under the tank. Well, good news!!!
I don't have a major problem.....I don't think. If I can surgically remove that small bolt without scaring or bending the valve, I may get lucky. FYI. The opposite bolt on the other side of the compression release is 3/4 backed out. It was certainly next!
