PVc braided line
While doing some tuning and many jet changes, I decided I can't stand that steel braided line anymore. I went with this old look but a newer material from Motion Pro. Also used the special clamps for a cleaner look.
V
Looks good Al :cheers:
Is that a Doherty plate? Will your carb bowl drop and clear with out removal of the plate?
I've been lookin at that set up.
Thanks V
Yep it is, dropped it 4 times today with some jet changes and never had to remove the backing plate when I dropped the bowl.
Very nice Al, I would like to do that material myself as it won't wear against the engine. Where did you order it from?
Thanks,
Ray
Chopper Dave
SIICK!!!
looks good Al! :up: I have used those clamps before.....we use them on some of the water lines that are on the molds that we run in the machines....but they are the bigger version....
lee
looks good Al, I especially like the clamps. You do need to get on top of your polishing though! :D
Gas yep thats what is/fuel line, I was lucky that it came in all 3 sizes. And Ray I just ordered it direct from motion pro. Motion Pro - Quality Motorcycle Cables, Tools and Controls
If you have to remove the line you break it off with the crimping tool. I did not use one of the clamps on the petcock of the fuel tank however, just in case I'm on the road somewhere an I would have to pull the tank.
