Scared myself, need some help
Uriel
Head Bungler, definitely not in charge
Hey all!
So I went and put a new, topped up battery in my 05 Pitbull yesterday, and tried to crank her over for the first time. It cranked twice and died. Now the battery tests normal but the horn won't even sound, no dash lights, nothing. I'm not exactly a world class mechanic, where do I start looking for my problem? Also, I think the bike has the updated wiring harness, there's a bank of LEDs on whatever it is just in front of the battery that all the wiring goes to. Also zero lights/response there.
Ideas? Suggestions?
TIA
Uriel
mleach72
Did you get all the wires hooked up correctly? On my '05 pitbull, there are 3 on the positive. The main cable to the starter, one running to a post that connects to the voltage regulator (there should be an inline fuse between the battery and post), and one running to the ehc. There are 2 on the negative. The main ground cable and one running into one of the harnesses.
Coolbreezin
Okay, back on track, the battery is definitely not my problem, the no start, no power through the harness is my problem. Does anybody have any suggestions or places I can look for help on that?
About 8 years ago I had a custom bike builder completely rewire my bike just to remove the ehc ($1500). I have only three fuses now. I haven't had an electrical issue since. I highly recommend doing it to avoid any future screwing by Sheldon Coleman (founder of BDM).
Uriel
So I've come across a.i. chatter about a master fuse I can reset, but I've got a 40-Amp in line with my main positive cable and it's good. What else should I look at to get power from this battery to the bike?
Also, since I'm going to try and take some time to look at this again today, does the main negative cable on three 05 pitbull ground to the engine case or the frame? Might as well check it and make sure it's good...
Mikeinjersey
Welcome to the site!
Provided you have the same or similar wiring to BDM, the 40 amp fuse (resettable circuit breaker) goes to the VR and protects the battery in case of a short or overvoltage from the VR. That would not be your problem it's job is only to charge the battery.
Some lithium batteries (without reset buttons) need to be disconnected and reconnected after it senses an issue before they work again. Give it a try and be sure to have clean and snug connections when you reconnect.
The positive side (cable) of the battery goes to the starter and the smaller wire goes to the EHC. You may have a fuse you can't see installed on that wire. If you follow the wire back to the EHC you may find it. If you find it check it of course . The EHC does everything and if it doesn't get power nothing happens. If it turns out a fuse was not installed you should install one so the EHC will be protected from a shorted battery in the future.
Follow the negative cable back to it's source and make sure the connection is clean and snug. I'm not sure on your bike but it's definitely frame ground.
If none of this helps you, the ignition switch would probably be you first place to start troubleshooting. Come back with how you make out.
Yes, I would remove the ground from the frame/engine and file down to bare metal to the engine/frame and to the ground battery cable it flushes against.
I'd also buy a ground cable and bolt that to the engine to frame, or vise verse. This way I have ground to the frame, ground to the engine, and ground to the battery side, meaning all 3 grounds.
La Rana
Hey all!
Ideas? Suggestions?
TIA
Uriel
Hey all!
Ideas? Suggestions?
TIA
Uriel
MIght be good to post a pic of whatever it is with the bank of LED's. Could someone have added an inline fuse bank?
Mastiff Rider64
After reading everything you've tried, I'm worried that you may have fried your EHC. There is a possibility of a fuse or a breaker being tripped but based on my 24 years of electrical background doubt its a fuse.. So this all started after installing a new battery, correct? You put a new battery in and it turned over twice and then boom nothing. So you buy a bigger battery and one that a lot of us don't run because experience has taught us those batteries (older versions) don't like the vibration from our bikes. But our bikes are rated for a 320 CCA battery which is 400 CA, you installed a 600CCA which is 750CA? So you almost doubled the amps running thru the wiring and circuits. Which a lot of us know that the wiring on these bikes are under sized from the factory. You could have burnt a wire in half with those kind of amps running thru them.
So, is anything electrical working on the bike at all? Turn the key switch on, don't do anything else, just look for a head lamp, brake lights, the sweep of your speedometer, try each turn signal, try turning on your 4 ways. check your tag light and if nothing you either have no power to the EHC or burnt the EHC up. Th check and see about power to the EHC you'll have to get the pin read out for the main harness and EHC track down the wire suppling power to it and see if you have power there. That is step number 1, once you determine if you do or don't have power to the EHC will determine step 2. There should be documentation on this site or you could call either Curtis or Knothead and they could send you the documents you need or post them.
Honestly hate you are going thru this. But one thing I learned with having a Bigdog, it will make you a better mechanic. Good Luck and once you get thru step 1 we will decide what step 2 is.
Uriel
Well, so far its definitely the management chip on the dang lithium ion battery. Seems if I let it go a couple of minutes with the negative cables detached, it'll fire up the horn, lights under the speedometer, etc. As soon as I hit the starter again, boom it shuts off.
I found a thread about the compression releases on the cylinders, but apparently I'm a hopelessly visual learner. Anybody have a photo or diagram of where they sit?
Dump that "battery" and grab a Deka. Dogs aint too fond of the lithiums. If not, you will prolly be chasing gremlins. Good luck. Comp release is down in the cylindr head. Covered by a rubber boot. Stick a finger in an you should feel them.
Uriel
Well, new battery in hand, I'll have to look at the Dekas at some point.
The compression releases were butter smooth, dude at the battery store said straight out that the last guy should have asked, apparently I could have started a fire if I read less careful. Screw saving weight lol...
Anybody have any thoughts on this oil reservoir? I'm about to have to take channel locks to open her up lol.
They can be a pia sometimes. Wrap it good with tape and break out the channel locks.
