2003 Chopper S&S 107
Getting ready to remove varnish from the tank, I have a question related to the tank bungs located underneath the tank connected via 1/4” braided fuel line. What is its purpose? Is this a venting system, fuel equalization? Both side are completely blocked. I can’t not blow or suck air through. Is it possible it is cosmetic?
I would think of it was fuel stabilization and it was blocked, when inserting weed whacker line it might feel a little spongy or a little give. It is solid, and both sides allow for the same length of whacker line when inserted.
I’ve been running clean gas for a bit now, there’s a pretty nice layer of varnish on the bottom of the tank. I’ve had a couple issues with clogged jets in the carb. I could leave it and run an inline fuel filter as there isn’t one today. The acetone scares the hell out of me, the paint on the bike is flawless.
Are you seeing actual varnish or perhaps a colored liner? Lots of these tanks were 'lined' from the factory. After time the liner will flake off and cause issues. Relining can fix it. Or removing the liner altogther? But a fuel filter will help either way. Keep it filled and rolling and Id bet you'll be good. Keep us posted.
That sounds like liner color. They used a green. Ive got it on both the 04 Chopper and 04 Pitbull. I'd bet its liner. Drain n dry ur tank. Bet its still greenish. Varnish is usually a brownish color from my experience.
Drained and dried the tank the other day. Still green. Pulled the bowl off the carb and it was clean. You’re probably correct on it being the liner. I’ll fill it with gas and install a filter and call it good. Really appreciate the knowledge this site has. I was close to dumping a quart of acetone in the tank and I’m 95% sure I would have messed up the paint. Saved my ass!
Chong
U-235
My experience..
I triple wrapped tank. Tape, brush on liquid mask, plastic.
Still got some paint damage, leaked at pitcock. You like your paint i wouldn't attempt it . There are a couple places that will relign it. Cheaper then a repaint . And acetone won't touch the old liner material.
My experience..
Im going to leave it as is, after chatting with HMAN it’s more than likely the liner. I just ordered a new braided fuel line and inline filter. I do like the paint so no reason to attempt anything that might ruin it.
Another question,
From time to time, I notice an oil spray pattern on the left side of my oil tank, it’s noticeable after longer rides. I believe this is coming from the breather valves, my guess is they need replacing due to age. I do not notice an oil level drop nor so I believe this is minor as of now.
I was curious if there might be any concerns continuing to ride with the plan to replace all rocker gaskets in the offseason?
Another question,
Check the rear rocker box. The lids can spring gasket leaks. Or the rockerbox gasket itself. If it was the right side Id say pushrod tube gaskets.
