ALDog
OK guys I have a question. I have an 08 Ridgeback (it is awesome) and I'm having only one problem with it. When I got it a few weeks ago I leave the dealer and get about 20 miles down the road and it started. When I let off the throttle the Oil PSI light started coming on. I pulled off to an exit and called the dealer and he said ride it back as long as it's only coming on when you decelerate. To make a long story short, I headed back and it got to where it stayed on. They met me and took the spring out of the oil pump and stretched it. That helped for a bit but before I could make it back to the dealer it was on again. They came and got it with a trailer and when we got back to the dealer, he put a gage on it and it was idling at 18 PSI or so. I head home 120 miles and it came on again before I got home. They had called BDM and they said if it is idling hot at 18 or so on the gage don't worry about it. I took the spring back out of the oil pump and stretched it 1/16 inch. That fixed it for about 400 miles. I went for my 500 mile service this weekend and it was good until I got almost all the way home. Interestingly the spring had gone back to its original length. I stretched it again by 1/8 inch and its OK again. Does anyone have any experience with this? Is there a stiffer spring I can by or is there another solution?
