Rintintin
An electric gremlin has moved in to my 2006 Mastiff. Two weeks ago after a brief, interstate ride, the voltage regulator (VR) started smoking heavily and pretty much melted the wired coming out of it before I got it out of the garage and the battery disconnected. Prior to the VR meltdown, everything was running fine, all blinkers, lights and brake lights work fine. There was no other visible damage. I checked the circuit breaker under the seat and the little tab was not indicative, I pushed it but it didn’t click or anything. Opened the primary inspection over and did not get an overwhelming “burning” smell.
I ordered a new chrome VR from Donna. When it arrived I installed it. The bike started fine, but the voltage at the battery did not change from idle to rpms. At that point, I assumed the rotor or stator was bad and ordered a new stator from Donna (BDM170-00387).
I installed the rotor and stator. (FYI, the one I removed was a Phelon and I had to grind some of the primary case to get the new one to fit.) I started the bike, and there is still no change. The voltage at the battery remains around 12.4 at idle and up to 12.6 at mild rpm. When checking AC at the stator I’m getting 18-19 at idle and it goes up sharply at rpm.
I worked with Josh who walked me through bypassing the circuit breaker to test, and nothing changed. I then ordered another chrome VR from Donna, just in case I got a bad one. I installed it and there is no change.
I am not at all handy with electronics or meters, but it seems like something (power) is coming out of the stator but is not making it past the VR to the battery.
What am I missing? I had to REALLY wrestle with the stator plug to get it back through the engine casing, could it have become damaged? All electronics work just fine and the bike starts and seems to run ok, but I cannot prove power is flowing out of the VR and back to the battery.
I appreciate any ideas.
Thanks
Dave
2006 Mastiff, original electronics
Thanks
Dave
