Fuel Injection Re-wiring 08 K-9?
MIAMIVICE
Ok,
This winter, I'm going to re-wire my entire bike (08 K-9), including new handlebars and controls...Is there a perfered Fuel injected wiring harness available?
Thanks in the advance for the help
Has anyone done it? Please post pics if you have...thanks
seavee
The EFI wiring harness is seperate from the low voltage wiring harness that you want to replace. Just put some dielectric greese in all the plugs of the EFI harness and you should be good to go. The only wire i belive is tied into the main harness is the tip over switch that is in the ECM module, you will have to send your S&S vfi moduale to BDM so they can activate the tip over switch in the VFI, Unless you have a unlocked version VFI you can do it with the pro tune software. Others should be able to help out more on the subject.
