Butch Cassidy
EXCELLENT description.Popping on deceleration is caused by a LEAN condition. When you suddenly close the throttle, the incoming air is choked off and the closed throttle also causes the bike to return to idle on the very lean idle circuit. However, momentum of the bike is actually "driving" the engine in a sense, and that engine is still spinning at rpm that needs far more gas than the closed throttle position can provide. The engine is still spinning but the incoming fuel rate is very low, until just enough builds up in the combustion chamber to "fire" on the exhaust stroke of the engine.
