Deceleration popping
Discussion in 'Exhaust' started by Spikes05, Mar 25, 2017.
  1. Spikes05
    Spikes05 Member
    Lodi California
    05 bulldog
    Jerome
    Hey y'all I want to get straight on what causes deceleration popping. Some say it is a rich air fuel situation and others say that it is a lean air fuel situation. So which is it to rich or to lean?
  2. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Popping on deceleration is caused by a LEAN condition. When you suddenly close the throttle, the incoming air is choked off and the closed throttle also causes the bike to return to idle on the very lean idle circuit. However, momentum of the bike is actually "driving" the engine in a sense, and that engine is still spinning at rpm that needs far more gas than the closed throttle position can provide. The engine is still spinning but the incoming fuel rate is very low, until just enough builds up in the combustion chamber to "fire" on the exhaust stroke of the engine.
  3. Spikes05
    Spikes05 Member
    Lodi California
    05 bulldog
    Jerome
    So would you increase the intermediate jet or the main jet or both
    chubs likes this.
  4. bdm7250
    bdm7250 Guru
    Doug
    What have you done to your bike? Exhaust, cam, etc.?
    chubs likes this.
  5. bdm7250
    bdm7250 Guru
    Doug
    Morning, sunshine..:)
    chubs likes this.
  6. Spikes05
    Spikes05 Member
    Lodi California
    05 bulldog
    Jerome
    I changed the exhaust and the air cleaner. I used to have mean mothers and stock air cleaner and I installed hooker headers Darkside big radius pipes and an S&S Dual Runner
  7. Spikes05
    Spikes05 Member
    Lodi California
    05 bulldog
    Jerome
    I have had the V&H Big Radius in the past and I installed BCT baffles and that solved the problem. However the Darkside B&R is 2.5" O.D. and 2.25 I.D. and big city thunder baffles only make baffles for 2.25 O.D. So I am trying to fail in the jets and air fuel mixture.
    chubs likes this.
  8. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Try this:old2:
    Rottweiler, bdm7250 and chubs like this.
  9. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :disappointed:
    chubs likes this.
  10. Spikes05
    Spikes05 Member
    Lodi California
    05 bulldog
    Jerome
    Okay thanks I have .032 and a .076 and I was wondering if I should try the .033 and .078 combo.
  11. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Before you do that, did you try removing the Auxiliary bowl vent and readjusting the carb? look at the PDF, its #14
    With aftermarket air filters, this should be removed
    Big D Florida and chubs like this.
  12. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    What pipes and air cleaner are you running?
    chubs likes this.
  13. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    chubs likes this.
  14. Spikes05
    Spikes05 Member
    Lodi California
    05 bulldog
    Jerome
    Why would I do that I am running a S&S Dual Runner and it has the bowl vent built into the assembly. Does it need more venting than that?
  15. Spikes05
    Spikes05 Member
    Lodi California
    05 bulldog
    Jerome
    Hooker Headers Darkside Big Radius
    chubs likes this.
  16. Spikes05
    Spikes05 Member
    Lodi California
    05 bulldog
    Jerome
    Did it feel like it was stumbling kinda like it was beginning to run out of gas but only off and on while you were cruising at those speeds?
    chubs likes this.
  17. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I am running the BR and the dual runner also with the vent removed because that's what they recommend you do, I tried 32 and 78 and at while cruising at 50-55 it would sneeze thru the carb, per their (S&S) carb adjustment guide, they recommended to bump up the inter a size, that's why I'm running 33 and 78 now without any hickups.
    You ask why would you do that? because its not running right now. Follow the istructions they have on the PDF, what you have to remember is no 2 bikes are a like because of tolerances, think about it, from .032 to .033 is .001. What if the tolerance is +/-.0005, you could have a .032 at .0315 and a ,033 at .0335, that's .002 difference. Is that going to make a difference? You bet it is.
  18. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :agree::stupid:
    bdm7250, chubs and dentdude36 like this.
  19. Spikes05
    Spikes05 Member
    Lodi California
    05 bulldog
    Jerome
    Okay thanks I will set it up today with a .033 intermediate jet and a .078 main jet and I will pull the auxiliary bowl vent. I will let you know what happens tonight. Thanks again
  20. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :old2:Please do, we like to hear a happy ending:whoop::chopper:
    Just try removing the vent first before you bump up the jet
