For the computer mechanic in training (me) and anyone else needing to be on the same page.
Cam and crank sensors are basic hall-effect makers. Think of 2 communication lines. 360° is one long square wave. The cam comes around twice, so this now becomes 2 balanced square waves matching the 1 long wave. I now know my cam will make 2 short squares, my crank puts out 1 long square. The fundamentals are correct, but I start confusing you with all the cuts in the crank and those are the 1 long square cuts, all cut down waves to make 1 it gets confusing, so just think of volts are numbers 'that can be measured is = current.'
There is a resistance of a wire so show me the inches, feet, yards, it is still one long wire with a measured resistance. The cam sensor wire is one long, non-magnetic (copper) wire, wrapped around a magnetic pin or small dowel; to produce a current that moves up the wire. Turn the crank backwards and the current heads up the other wire = AC.
So one pulse goes up a wire that can be measured and this is now an input signal. If I knew my h-d resistance between their cam sensor wires, I measure mine against that spec, if I am within range, I head for the other variables.
I have no clue what the who or watt, but where is your forum sponsor that can check those? Go to his website, look up your year H-box, run thru the left turn signal reset procedure. Hell? I don't know if this is generic across the whole H-box updates and that sequence to clear the RAM and start the bike in ROM?
1. I pull both plugs; I have to check spark is step...
2... but here I am first is to reinstall a plug [take your pick] place it in 1st gear and see if the rear tire drags on the floor when I push it for compression; swap to the other cyl before I chase my tail no start.
3. Com is out of the way, yes? I want spark is next.
4. I have spark and compression, I will now see if there is gas
a. vented open from the tank cap.
b. no bent/kinked/swollen internal fuel line.
c. petcock flows like a mother.
d. float is not stuck closed so no fuel in bowl; pull drain screw.
e. crank sensor produces spark don't forget; no start = coil is good.
f. I can test my coil wire is touch which side is hot at the post so the H-box sends that out to the coil? Key to H, H to coil wire, yes?
