Few Hundred Miles
Actually it is the bearings in the left side of the case that are most likely to cause the problems. The main drive gear bearings do tend to fail as well once the others start to wear. It is common to need replacing before or sometime soon after 10k. I've replaced the in literally hundreds of transmissions and have seen them go with as few as 2k miles. If you ride it hard, most likely it will wear sooner. If you have a massive open primary drive, over 3" and one with no outer bearing support, your bearings will only last a few hundred miles.
Yes, if you are leaking oil bad most likely you have worn bearings. How many miles on your bike? If you don't have a way to rebuild it send it to me, I've got all the parts and tools needed to do the job:2thumbs:
Knowledge Base:
With 38 years of mfg. belt drives I cannot understand the quotes referring to belt drives and bearing wear by some members with no mention of the breakage of shafts and clutch parts on factory stock bikes.
How many failures are their with the Karata Belt Drives ?,Rare if Any.
How many failures are their with the Karata Piranha Jr. Clutch ?,Rare if Any
How many failures are their with the Karata "Belt" ?, Rare if Any
HOW MANY FAILURES ARE THEIR WITH ABOVE FACTORY PARTS ???
Explain why the shafts only protrude out 2.500" on the BigDog and 5.125" on a Harley shaft and they do not break as the factory BD's.Could their be something wrong with the design or for the real mfg. of the shafts and gears or is it blamed on the heat treat contractor.
Bearings on the BigDog Shafts are NOT WORN OUT due to a MASSIVE OPEN BELT DRIVE as some would want you all to beleive, with or without Outboard Bearing Supports.
Just a little more knowledge for you members, Karata did MFG. IN HOUSE at their ONE LOCATION in the early to mid eighty's complete DRAG RACING AUTOMATIC (no clutch) transmissions in 3 speed, 4 speed and 5 speed versions for Kaw,Suz,Honda.
If any member is in need you can PM or reach me at
karata@karata.com. for a straight answer to your question on belt drives or clutches.
jim@karata
