1. Mix water and dish soap in a paper cup, and find and old toothbrush.
2. Drop the toothbrush in solution, then as the bike is parked on the side stand, have the wheel cocked so the soapy water runs down the bead of the rim and tire.
3. Cock the wheel to the other way so you keep feeding the rim and tire meeting points and watch for a bubble.
4. Remove tire cap and soak the whole tire stem and schrader valve. No bubbles? Press the valve down so you shoot the liquid out, rather than run more vapor into the rim and cause oxidation and hard to remove tires off the rim's bead, etc.
5. OR... Remove wheel, find a pool and dip the rim so the whole tire, the whole rim and bead expose a bubble coming up from some point? Rotate N-E-S-W kind of rotation and start at the tire stem at S position.
6. Replace tire and call it a day.
7. Run tire sealer and not much or the more you install the more you clean up the crap when the tire is changed.
