LA_Dog
Go Fast, Go Faster
Hello fellow BDB'ers- Need your input. Ok so latest on my dog is I'm rebuilding the top end due to a melted piston. What a pain in the effing a$$ trying to track down all the right parts for the edelbrock heads, pistons, gaskets etc... After I get this all done I will post a list of parts in case anyone else with an early TP "mutt" motor needs the info. I gotta say the motor has all very good parts in it- they are all just from different sources (SS, TP, Jims, Wiseco, Edelbrock, Crane, etc), with some no longer manufactured. Edelbrock, SS, TP have all been extremely helpful!
I am keeping the edelbrock heads instead of swapping out for SS heads. had a long discussion with Wink Eller today- what a cool guy - he knows all about these specially made edelbrock / BDM heads and says they out perform the SS heads by a long shot / definitely keep em. They are not the same as the 'regular' Edelbrock heads that were for sale on their website. I confirmed this with a sr tech at Edelbrock, and also with a sr tech at JE pistons (they made all of the 4" bore high CR pistons for Wink on these specific heads).
So, I can have JE run me a set of Wink's high CR dome pistons but I gotta buy 4 pistons. that's expensive. my other option is to go with regular SS flat tops and deck the heads to raise CR. My goal is 10.5:1
On to the cam- I have spoken with Bob Wood, Dave Mackie, and of course Wink. Each has given me a unique view on choices and reasoning. The take-away from all this has left me with the following choices:
For ref, my current cam is a Crane 304 600 lift
1. Mackie DM595 @ 10.5:1 - strongest at top end over 5500
2. Mackie DM580 @ 9.8:1 - stronger than the crane across the board
3. Wood W9b @ 10.5:1 - 631 lift Andrews cam with Bob's custom grind
4. Wood W9f @ 10.5:1 - 650 lift Andrews cam with Bob's custom grind
5. S&S 625 cam @ 10.75.1 - suggested by sr tech at JE
I have the baker six OD - I spend most of my riding in town, dodging a__hole drivers, in the 2500-4500 rpm range. Hooker 2-1 header, may change it to a Supertrapp or RB Racing LSR 2-1. I ride my bike like I stole it. XxX Super G carb, Twin Tec ignition
Did I leave anything critical out? What are some of you using, what would you suggest. I've seen some dyno charts of 107's running the Wood 9b / 9f cams putting out 120+ hp/tq numbers. :up:
But of course, longevity is important too. and only using pump 91 gas.
