03 bd chopper
Spike D
Let out of throttle or down shift chirping noise any help appreciated
The 03 Mad clown pulley design was the worst with this problem. What has happen, is the pulley is worn and/or the teeth are coming loose. Might even check the spokes on the pulley for cracks. The good news is, HDM has redesigned this pulley, and beefed it up, but still maintained that design. Plus it has a Teflon coating on it. Give Eric or Donna a call and they will fix you up with a new one. 620-680-0395.
www.bigdogpartskingpin.com
Spike D
knothead
Second Chance Customs
Like Mr.Wright said they have better designs of the mad clown now....but also check to see if ur belt is loose...i have had them to chirp letting off the gas and usually that is why mine have chirped...or could be your getting a little bit of primary oil or motor oil on it from a little leak in that area
Spike D
Thanks also my ignition switch went out any 3 positions with work for that application
knothead
Take a pic of the one you have now cause it may or may not be the stock one....if its the stock one HDM has them as Mr.Wright stated above...he also posted there website above also....if its not stock it maybe a sportster key switch...take a pic and post it so we see what you have to help you get in the right direction
Twincam8888
Easy things first, as mentioned, check for a loose drive belt.
tcrowelljr
I had the same problem with my 04 Chopper. New pulley fixed it.
