Wtb front 21 spoke 18 250 rear rims. Sissy bar / struts .
Lifetime Supporting Member
First we need to know what frame you have. Post a picture of the front engine mount where it connects to the frame
You have the Rolling Thunder frame. Get with Donna, she can fix you up.
Someone get him her number.
Found my glasses, send Donna a text, she can take care of all your BD needs.
620-257-2009
Spoke rims wouldn't be factory. I'm not 100% sure what options spoke may even have for a 250 rear. Also any spoke rim you need to make sure it will take a tubeless tire.
Adamv
Thank you for your information. I appreciate it
Adamv
Hey I have a question that I can't find in the forums. I had open pipes on my bike I put the stock ones back on it because I like them.. now it pops or backfires once when I start it. what is the stock jets for that carb and or is there an easy adjustment from the outside ? air, fuel, excetera excetera
knothead
RIGID4LIFE
107 is .031 intermediate...main .076....111,113,117,124 is .031 intermediate ... .078 main....but thats starting point have to tune from there...idle air screw is usually around 1 1/2 rounds out from bottom if all is set right...u can tweak 1/4 turn from left to right for fine tuning from the 1 1/2 turns out....screw it all the way in but NOT tight just let it touch then back it out 1 1/2 turns and start the bike and see how it acts then go from there....if rich screw it in a 1/4 turn....if lean of course screw out 1/4 turn....idle air screw is just for idle to 1/4 throttle....then intermediate control 1/4 to half throttle....main controls 1/2 to wide open
JR03CHOPPER
The Mutts used to have spokes. Almost bought a set of "pull offs" from Carl's Speed Shop a few years back.
