Wiring diagram
Lifetime Supporting Member
I have an 08, but it only goes to chapter 12. Electrical is chapter 13. Got a broke pin on an EHC and trying to find out where it goes.
Srodden
I do but don't know if I have pdf of it. Willing to help if you can't get a file.
I will check but I'm sure someone will get it to ya let me know.
I have an 08 and 2011. At work now 2nd shift I'll check in the morning not sure how many chapters in each manual but I know they both are complete
Thanks, if you have them I can use them. I have an o8 and 09 in my shop now.
That explains why everything is dead. Thanks. I died going down the road, he wiggled the plugs and it fired back up, then died again later. No power to anything. Found that pin broke off.
Thinking out loud here, with that being an out put power to the key switch, I could run a hot wire directly to the key switch and it should work. OR, is it an input to the EHC from the key switch.
jbs1968
MEMBER
It says input from key switch so with EHC I believe this is a input from ground through the key switch.
