V&H Pipes
Gathering
I have a 2008 K9 and I'm thinking on changing the super trap original exhaust to V&H big raduis 2 to 2 exhaust system. My bike has EFI. I see a lot of V&H pipes for carb only. What is required if I want to do this change. Any suggestions would be greatly appreciated.
Jwooky
Nothing. The EFI system has a fuel table calibration range of 20%. Pipes easily fall within that.
As you ride it will self tune, and adjust where needed.
Ideally, after ~50 miles you would Merge the learned maps to write them permanently into the ECU so you don't loose them if you loose battery power.
41bigdawg
Let the Big Dawg eat !
Dont the EFI dogs use O2 sensors? Ive never looked at one so just asking. :chopper:
pknowles
semi-retired...---... GURU C7Z06...---...
Lifetime Supporting Member
Bunch of different companies sell the weld in 02 sensor bungs. Just make sure you drill and weld in the right spots. Also, get the right size bung. I know there are at least 2 different sizes.
SEAL-rider
Are you just going for sound or is performance a factor? If performance 2 into 1.
41bigdawg
You won't need a Fuelpak on a Big Dog, it is a wideband system that will auto tune within 28% of the fuel table. You should be well within that parameter with just changing the pipes. Harley's are a narrow band or closed system that will not auto tune and you need a piggyback tuner like a fuelpak to add or subtract fuel from the base table.
Kenny_B
Lorne, what did you end up doing in your quest for aftermarket pipes? i want vance and hines big radius but i've been told they don't make em to accommodate my 09 k9 with efi.
Hi Kenny I ended up not changing the stock pipes. My reply back from V&H was that they don't make pipes for the EFI bikes. If you do change them, you will need some type of fuelpak to make the bike run properly. Good Luck
Jwooky
That’s not true. You do not need a “fuelpak”. The VFI will self tune to support new pipes.
You may also be able to make a bracket for theirs pipes to fit your bike. You can add bungs for the O2 sensors if need be too. I did on my current pipes.
