Shocks ?
Husky Big Dog
I have a 2000 big dog husky was wondering what the best shocks are to use and I’m a pretty big guy lots of weight the ones I have on it now seem to bottom out pretty easy thanks in advance. ✊
roadie1389
I believe your frame is a standard softail. You can go with the Progressive 422, get the Heave Duty version. Make sure you get the 422-4001C. They have the eyelets on both sides of the shock. Not sure what shocks they used on that older model but you should also get a new bolt and washer kit.
Check out wildsteedworx.com, he is a member on here and carries those shocks. I use them and love them.
Olgreg
Good evening fellas, I m in the market for some shocks as well. The bike is an 03 Mastiff. Suggestions? Are the same as the Wolf?
1 B.M.F.
Wild steed worx 1(619)823-8557
He is in California,leave him a message for what you need and he will call you back.
Olgreg
The progressive 422 shocks won’t install due to a bolt coming out of the transmission keeping the shock from lining up with the swing arm. Anyone have experience with this?
Olgreg
I know that bolt has been addressed a couple times. Don't remember what the fix was. I'll try to find the thread on that. I'm sure Curtis will know too
Olgreg
Update.......I talked with Curtis and the remedy is, 1 go with the slim bodied shocks. Direct fit. 2. Remove the transmission stud and replace it with a flat socket head cap screw. He mentioned using a heli coil but I found a 7/16-14 bolt that will be perfect. Also, you need to bevel the metal tab to allow the bolt to countersink and flush mount allowing enough room for the shock to mount. I chose option 2. In the process of beveling the steel to allow for the flush mount.
