Protecting the bottom of your frame.
Ernie12
I had my K9 bike up on the lift and was checking out underneath. I noticed some good scratches I guess from trailer loading in the past. I bought some Dupli-Color Rust Barrier and brushed painted in the scratches. It says it seals corrosion, is impact resistant and drys to a flexible rubberized finish. After it cured I put some clear racers tape the length of the bottom of the frame to help protect against any future scrapes.
Do you guys do anything to protect the bottom of your frame?
pknowles
semi-retired...---... GURU C7Z06...---...
Lifetime Supporting Member
Avoid speed bumps. Some will catch the frame. Your idea sounds good though.
Thanks for sharing.
Nukeranger
Nukeranger
I’ve scratched the bottom of my frame a few times entering gas stations with a curb that was a little high and I didn’t take a larger entry angle. Anyway, I haven’t done anything to repair it or protect it. Maybe I should. And, speed bumps really suck.
Mickeetwo
Mine has scratches all over it, but that is good idea. Thanks for the tip :old2:
TapioK
Not sure how much paint and tape helps when frame is hitting the curb etc, but having a fresh coat of pain there is never a bad idea
No H2O
I regularly inspect for scratches that go through the paint to the metal.
Frame is black so I brush on Mar-Hyde liquid (comes in black) anywhere metal is exposed
that tends to be one of those "out of sight-out of mind" things. thanks for sharing.
Nukeranger
Nukeranger
If you don’t put your Big Dog on a Lift, you won’t see it either. That’s my solution until I see the bottom of my frame.
