Need Paint Codes for Touch Up
Lifetime Supporting Member
Give me a little time. I have all the paint codes, but what I don't have is the year it was used. I'll get back to you soon.
Looking at the pictures, looks like you need more than just a few touch ups. I was going through the paint codes I have, and I don't believe they go back that far. I only have one orange, and it's not the same as you have. The paint they used back then was PPG, and I don't believe they started using candies till about 03. Which is most of the paint codes I have.
Give me your email and I'll shoot you what I have.
Thanks, my email is hardcorecustompainting@gmail.com
The goal is to fix whats chipped with the original colors if not, ill just repaint the top orange, purple and inside of the flames with an airbrush with a similar color. Appreciate the help.
Don't mean to hijack but I'm also looking for paint codes for my 08 K9. Any luck finding them?I just need the base red color.
The red on yours is a House of Color candy wild cherry, with a base, more than likely, b01 silver. Only number I can find is, Brite Candy Red-DT124-BD1124
TapioK
Lets see if this paste works.... mine Looks the same Color and I got this info:
Bright Kandy Red
House of Kolor
Base Coat BC-11
Top Coat UK-11
Cleaners
Wax & Grease remover 320/sx7005
Water Bourne Cleaner DX103
Primers
Black Epoxy Primer DPL90
Epoxy Primer Catalyst DP902lf
High Build Primer K-38
HB Primer Catalyst K201
Sealers
White Sealer NCS2003
Gray Sealer NCS2004
Black Sealer NCS
Sealer Catalyst NCS2200
Clear Coat
Clear for production parts Global 2021
Speed Clear for repairs DC3000/4000
SC Hardner DC3085
Buffing Compound
1st 3M Perfect it 6063
2nd 3M Perfect it 6071
Undercoating
3M 8883
Hehehehe, figure this shit out
All the candy paints are the same color. What changes the color when it is painted, is the base color underneath. The red candy may be sprayed over silver, gold, red, etc. This is how I do ghost flames. I'll spray a silver base, the do the flames in a different color, then spray the candy over it.
The information I have doesn't tell me what the base color is on these bikes.
Mike, yours is a brandywine candy.
Jersey Big Mike
Ok, so do you have the codes for brandywine candy?
