BiggJimm
2003 mastiff has been sitting a couple years. Checked my fluids and installed a new battery and new gas.. Fired right up and then I noticed oil coming from the air cleaner. Lost about a quart. Gained access the the oil pump check ball and gave it a lite tap to seat it. Ball looked good. Tank was close to empty so I added a half quart. Started the bike a let it run until oil erupted from the tank fill hole? Siphoned some out and restarted it. Watched the tank level rise then shut it off. What gives?
