How to get gas tank off 2006 mastiff.
Apollonick
Hello guys yall have been a big help here for my battery starter and other needs i finally got to getting into fixing it and realize how much stuff you have to take off just to acess other bolts and stuff. If any one can tell me how to take the tank off so i can replace the ignition i would greatly appricate it here is a picture of where im stuck there is only two bolts holding a plate to the frame and the plate needs to be removed to slide the tank over the frame how do i get this plate out ?
Just like to ride
Jwooky
That plate (item 18) has two rubber grommets (item 20) on each end that engages into channels in the tank.
To remove you have to rotate the plate 90 degrees.
To do so, temporarily leave one (item 21)bolt loosely in place, remove the second.
Then use a long 3/8" extension on a ratchet inserted into one of the square holes in the plate and pivot it 90 deg around the bolt.
Once the plate is disengaged, you slide to tank forward to disengage from the the rear mount (item 12)
Apollonick
Thanks so much jwooky i was wondering what the square hole was for and do i need to soak the rubber in anything it does seem hard and i dont want to crack it wiggling it out
Jwooky
I have never had to, but a little lube never hurts
Apollonick
Okay so i figured i have to take the crossover valve off that goes from tank to tank number 15 in the picture to fit the 3/8th extension in where 14 is labeled because it allows more room from top of head to tank
Jwooky
Correct, you will need to disconnect one end of the crossover hose (15)
Just slide the clamp (16) to the middle of the hose and pull it off the hosebarb. (17)
Sorry should have mentioned that.
Its probably set on there pretty good so will likely need a pick or screw driver to work around the circumference to free it. Good time to replace it too. It’s just 1/4” fuel line you can get at any auto parts store.
Apollonick
Have I ever mentioned how proud I am of all the members for being so giving with the information needed by the new members and any that ask???? Thank You.
Woodbutcher this fourm has helped me probally more then any mechanic/motorcycle/vehicle fourm ive been on. Also thanks agakn jwook ! Yall have helped me on questions ranging from battery to tire to this etc and yall reply quick its a great community.
Ernie12
Be ready for more fuel to come out when you take that crossover tube off even if you think you got most of the fuel out.
awg
Since your going to replace it anyway, just cut it in the middle. That way your not dicking around trying to get it off the connector.
Apollonick
Do i reuse the clips that were holding the fuel line on ? Its amazing how much has to come out to replace the ignition i guess they want you finding anything else that may be wrong on your way. The tank is blocking the torx bolts holding the ignition the plate is blocking the tank the line blocks the bolts
