Jersey Big Mike
100K mile club
So I go out the other day and the bike is good.
Go out the following day and I pull the clutch in and the cable/handle clunks and suddenly I've got WAY to much slack
Jack the bike up the next morning and adjust clutch (both ends to be safe) Did fluid change a week ago.
So I take it for a test ride and now its noisy when I pull the clutch in.
Re-adjust to make sure -- still noisy.
Pull clutch apart as well as actuator.
Discover that the throw-out bearing is SHOT TO HELL.
Called Bandit and got the size of the bearing and ordered one in case I couldn't find it locally (I did)
Also learned that the Bandit clutch prefers the ramp set up from a 12 plate clutch not the easy pull used in a 9 plate clutch (or bigger bearings int he 9 pull)
Ok, can't find the bearings but when I replaced my transmiossion I got the actuator with it -- what looked to be a 12 plate version (2006 before BDM went to easy pull)
Call AAA to fix the flat on the damn truck so I can run 22 miles and go get the bearing.
Stop at local bike shop and have it pressed out and new one pressed in.
Get home, reassemble everything the next day (was too late and too hot to work on the bike much after I got home)
So Friday morning I get it back together and adjusted the clutch and install the ramp from the 12 plate clutch set up.
Go for a little test ride, clutch needs minor adjustment.
I go out friday note no problems.
Saturday morning we have run scheduled so I tweak the clutch adjustment about 1/2turn on the cable.
I leave the house, stop 1 mile up road -- station is virtually out of gas.
Go to next station, fill up
Go across the street to our meeting location (now I am a whopping 4 miles from my house)
I pull in, as I go to back into the parking space I pull the clutch in and CLUNK - extra slack again.
But wait, it's different this time, I'm in first gear and even if I let the clutch cable all the way out, the bike doesn't move.
Ok that tells me the cable isn't broken since when that happens and your in gear the bike moves.
Change gears -- doesn't move in any gear even if I tack up to 3.5K
WTF -- never seen this before.
Call AAA to tow the bike home. My crew rides off.
Get the bike home, it;s late, have lunch and decide to wait till Sunday to work on it.
Got up earlier than normal for me and started in it this morning.
Pull exhaust off so I can get at the actuator
check everything -- looks good, greased well. Adjust and it works -- fine tune the adjustment and re-install exhuast
Give it a try -- its ok, Shift a gear of two -- CLUNK
Again cable slack in gear and no rear wheel motion.
Pull exhaust, actuator, pull primary cover as well and try adjusting. CLUNK
WTF
Finally pulled actuator and put back in the easy pull ramp and all is well so far.
I be ordering new larger ball bearings this week so I can FINALLY find neutral on this thing easily.
Had the damn bandit on BOTH my K-9 -- 9 Years -- no one told to use bigger bearings or the other ramp(apparently the ramp I had which was used must have been bad!)
What a week.
At least it was while I was here and not half way to tennessee gathering as much as I wanted to be there.
WTF
What a week.
