WTB Primary Chain Inspection Cover 2006 Mastiff
Discussion in 'General' started by RABBID1, Aug 24, 2017.
  1. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Yup..completely inaccurate, with the thousands of rocker boxes I have done you only need 11.2 to 13.5 newton meters....
    Fatass and BWG56 like this.
  2. cdogg556
    cdogg556 Guru
    Full Member
    Folsom, Ca.
    John
    :disappointed:
    bdm7250 and BWG56 like this.
  3. RABBID1
    RABBID1 Member
    CATASAUQUA PA
    06 Mastiff 09 HD Road King
    Jugger
    Wow !!! Thanks for all the input , output , and torque specs...Will be ordering the new billet cover from Donna.....Got to love the forum !!!
    bdm7250 likes this.
  4. bdm7250
    bdm7250 Guru
    Doug
    Great choice, Donna and Derek are fantastic..:old2:
    BWG56 likes this.
  5. pauly
    pauly Active Member
    Full Member
    Weeroona Island South Australia
    2008 Big Dog Mastiff, R80st.
    Paul
    Sorry, but I'm with Curtis on the torques. There is no need to do the bolts up that hard
    and risk stripping the threads.
    Paul.
    Unsprung likes this.
  6. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Well as I stated many times before, the OP didn't strip the threads, he broke the corner off the CAST plate. In the 9 years I have been on here I never seen a post where someone stripped the threads. They have always broken the CAST plate due to improper tightening of the screws.
    Now with that said, last week I replaced my rocker box gaskets, there are 2- 1/4-20 screws in the center of the rocker arm assembly, around the 0-ring for the CR's, which have the same threads as the inspection cover screws, the torque spec is 15 - 18ft/lbs, yes ft/lbs, that equates to 180 - 216 in/lbs.
    216in/lbs is 2X the torque of the inspection cover screws. I usually shoot for the middle and I did torque them to 200/in/lbs and I did it to 4 of them and none of them stripped the threads.
    Most of the broken cast plates, and I'm willing to bet on this one, came from people seeing a small leak there and they crank down on the screw in an attempt to stop the leak, and what they hear is "tink" the corner breaking off. The rest of them have been broken when installing the screws incorrectly, meaning they don't tighten them down in a X pattern gradually.
    I will say the BILLET plate that he makes now is superior to the cast plate, it will bend instead of breaking but you won't strip the threads at 108 in/lbs.
    bdm7250 likes this.
  7. bdm7250
    bdm7250 Guru
    Doug
    Well said, can't argue that's some genius right there..:old2:
    BWG56 likes this.
  8. jbs1968
    jbs1968 MEMBER
    Full Member
    Springfield MO
    07 K9, 05 Bulldog
  9. KaptinAmerika
    KaptinAmerika Well-Known Member
    Full Member
    2006 Big Dog K9
    Curtis
    LOL....a few of the folks on here aren't worth trying to help or educate.
    Sometimes all you can do is walk away shaking your head and move on.
    Mr. Wright likes this.
  10. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
