Wire plus burned
Discussion in 'EFI Topics' started by Cesad, Oct 28, 2017.
  1. Cesad
    Cesad Member
    Madrid Spain
    K9
    Cesar
    I have no doubt about this team !! :):) Thanks
    francoblay1, chubs and cdogg556 like this.
  2. Cesad
    Cesad Member
    Madrid Spain
    K9
    Cesar
    When i have the bike ok for ride , i will prepare a presentation , of sure
  3. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    We are looking forward to seeing that for sure Cesar! And you on that baaaad aaaaasssss bike of yours smiling from ear to ear brutha!:old2:
    francoblay1 and chubs like this.
  4. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    On it Bro! :old2:
    :chopper:
  5. francoblay1
    K9 (2006)
    Franco
    We will talk about @Axel , he is located in Europe so it best to buy it directly from him and save money on Shipment & Customs hassle if it comes from the US.
    :old2:
    BWG56, chubs and cdogg556 like this.
  6. EMILIO
    EMILIO Member
    phx
    2005 chopper
    spider
    Cesad, before you throw anything into that bike think about why it burned up, i burned up 2 of the Wire Plus modules at like $250.00 each and it turned out to be my bike was over charging at like 16 volts, just some good info.
    francoblay1, Forsaken and chubs like this.
  7. Cesad
    Cesad Member
    Madrid Spain
    K9
    Cesar
    Thanks for the info Emilio, I will check . I have decided to change everything include the harness and ehc . What did you do to solve this charge problem?
    chubs likes this.
  8. PROFLYER
    PROFLYER SWOLE
    Denver, CO
    06 K9, 06 Mastiff (wife's)
    Sutton
    Not if your voltage regulator (VR) is bad. There should be a 40amp fuse that the VR runs to and then after the fuse to the battery. That's the only thing protecting the entire system from a bad VR. Check that before you go throwing other parts at it.
  9. TapioK
    TapioK Well-Known Member
    Naples, FL / Finland
    Tapio
    Unless I’m totally wrong Just remember the 40amp fuse practically protects the wire from battery to VR from melting in case the VR shorts. It does not protect EHC from burning from overcharging VR. The fuse breaks on short or when the voltage is over 40 volts on most fuses, electronics burn when charging is around 20 volts...
    francoblay1, BadDawg Bill and chubs like this.
  10. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Maybe he still has the breaker in and never changed over to the fuse yet, in which case the breaker only protects the VR/Battery one way, unlike the fuse. But you should add another 20Amp fuse also on the power wire to the brain.
    francoblay1 and dentdude36 like this.
  11. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Well did ya get it done?
  12. francoblay1
    K9 (2006)
    Franco
    Hummmm........... ok, so two fuses, hu? I only have a 40 amp fuse in mine... :oldangry:
    Send me a How-To on it!!! and how did you place that fuse carrier over there so it is not floating around?
  13. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    There's only 1-40 Amp for the VR/Battery and I mounted it using the top hole (see the upper pic in post #31) that mounted the CB, the other fuse was in the wiring harness that came with DOC's ESC, pictured below
    cdogg556, francoblay1 and dentdude36 like this.
  14. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Where do ya think he learned it from
    cdogg556 likes this.
  15. TapioK
    Tapio
    Hehehehehehehe
  16. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    His I think is a bit better than the original but at the end of the day the protection is a Relay. It will wear out... Eventually
    I just had my flasher Relay on my truck wear out after 19 years. Sometimes the Relay worked sometimes it didn't. It doesn't really make any sense to me how a Relay works 20% or less of the time rather than not at all but $10 later and my flashers work 100% of the time. So relays will wear out
    TapioK and cdogg556 like this.
  17. TapioK
    Tapio
    My point exactly, time will tell. No system is built bad on purpose. Only time will tell witch is best.
