Will this one work?? Red Line Oils 80W Motorcycle Gear Oil w/ Shockproof
Discussion in 'Fluids!!' started by nextbd, May 21, 2016.
  1. nextbd
    nextbd Member
    Fl
    2006 Ridgeback
    Alex
    Hi
    I have been reading about transmission oil, apparently the red line 75w 250 so i found on a local store the
    Red Line Oils 80W Motorcycle Gear Oil w/ Shockproof,
    So will this one work fine??
    Thanks!
    chubs likes this.
  2. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I wouldn't put it in mine. :panic:
    dentdude36 and chubs like this.
  3. nextbd
    nextbd Member
    Fl
    2006 Ridgeback
    Alex
    Thanks for your reply, Besides the spectro and red line do you know any other option??
    chubs likes this.
  4. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I would stick with the Spectro, you can order it from DOC's, Barnes Performance or off of Amazon. If your in a hurry and can't wait 2-3 days for it because your going to ride, put the Red line in it and then change it out when the Spectro comes in. Or just wait to change it until you have the Spectro, that's what Andrew and DOC both suggest.
    dentdude36, chubs and Brew like this.
  5. nextbd
    nextbd Member
    Fl
    2006 Ridgeback
    Alex
    I will do so, thanks for the info!!:old2:
    chubs likes this.
  6. nextbd
    nextbd Member
    Fl
    2006 Ridgeback
    Alex
  7. MossBerg590
    MossBerg590 Active Member
    Arizona
    06 Big Dog Ridgeback
    Tyler
    chubs likes this.
  8. JR03CHOPPER
    JR03CHOPPER Well-Known Member
    Orlando, FL
    2003 Big Dog Chopper, 2007 Big Dog K9
    JR
    I run the Red Line. Trans Fluid with shockproof. A lot of guys do. I use the gear oil for the primary. I have the old style primary (LSD). Baker reccomended either the Spectro or the Redline. I like it because any leaks are color coded! Pink Puddle...trans, Green Puddle...primary, or Purple Puddle...Engine Oil (Royal Purple). Its like fluids for dummys!
    kickstart and chubs like this.
  9. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    But if your bike don't leak the colors of the rainbow,[​IMG] how do you know whats in there :oldhardlaugh::sorry: Buddy, your not here that much and I can't miss the opportunity.
    I use the standard Harley primary oil in my primary:cheers:
    chubs, JR03CHOPPER and dentdude36 like this.
  10. kickstart
    kickstart Well-Known Member
    TN
    52 Pan,05 Bulldog, 07 K9
    Pat
    Back when this site started Redline Heavy shockproof gear oil, all synthetic formula was what most were using and if I remember correctly Baker was recommending it. Kind of like S&S said to use Mobile one until another company made them a better offer. All about the $$$$
    PROFLYER, chubs and 405bigdog like this.
  11. JR03CHOPPER
    Orlando, FL
    JR
    I expected it!
    BWG56 and chubs like this.
