Who makes big dog's wheels?
Discussion in 'General' started by linx, Nov 24, 2009.
  1. linx
    linx Active Member
    NashVegas, Tennessee
    2006 Big Dog K9
    Rob
    Hi there,
    New to the forum.
    Who makes big dog's wheels? Just curious so I can figure out how big the whole is in the wheel to find out what size hubs it would take.
    Anyone know who makes them and have technical specs?
  2. KnotSo
    KnotSo Admin
    Staff Member Lifetime Supporting Member Full Member Supporting Member
    Washington
  3. Byrddogg
    Byrddogg Active Member
    Sturgis, Ky
    2007 Bigdog K-9
    Jason
  4. linx
    linx Active Member
    2006 Big Dog K9
    Rob
  5. Raywood
    Raywood The Pirate
    Rainbow, CA
    2014 KMW Regulator
    Ray
    Might help if you update your profile to show what model/year bike you have. RC and PM made them and now Millenium is contracted by BDM to make them.
    Many threads here on this.
    Welcome to the site
  6. linx
    linx Active Member
    2006 Big Dog K9
    Rob
    I don't have a big dog. Wish I did. Just really trying to find out which bikes were made with RC components wheels, and if they are standard size opening that RC puts on all their wheels. That's why I wanted to know who makes their wheels.
  7. K9Anniv
    K9Anniv Well-Known Member
    Algonquin, IL (NW Chicago-burbs)
    2009 - 15th Anniv K9, #5 of 15
    Mike
    PM made the chrome wheels on my Anniversary K9.:2thumbs:
  8. Dugan
    Dugan Active Member
    Arma , Kansas
    2009 COYOTE
    Ryan
  9. vej
    vej Active Member
    Land O Lakes Florida
    08 Mastiff Limited Ed.
    Who Made These
    I wonder who made my wheels/sprokets, rotors? Anyone know the model these are??
  10. Raywood
    Raywood The Pirate
    Rainbow, CA
    2014 KMW Regulator
    Ray
    What do you mean by "standard size openings"? Are you referring to axle size? If so then they are standard 3/4" front and 1" rear.
    RC had the "Sheriff" or "Marshall" model wheels that were on my 03 Mastiff. They were the 5 spoke style and I really liked them.
  11. Thumper
    Thumper Well-Known Member
    10 Glide, Custom bobber
  12. linx
    linx Active Member
    2006 Big Dog K9
    Rob
    Like the opening in the wheel, without the hub. If you take the hub off, what is the opening in the wheel.
    I just checked out those wheels, and they look nice.
  13. Raywood
    Raywood The Pirate
    Rainbow, CA
    2014 KMW Regulator
    Ray
    Not sure why you would need that as all wheels come with hubs and are based on width, height and axle size.
    But here is what they look like when they are apart.
  14. linx
    linx Active Member
    2006 Big Dog K9
    Rob
    Thanks for the pic.
    Ultimately I'm looking for whatever wheels RC Components made for big dog.
    I want to buy a big dog in the future, but as of now I'm stuck on a VTX. My bike is shaft drive. RC Components has the shaft drive wheels on lock down as they are the only company that make a shaft drive hub adapter. So, I have to use their hubs, and they claim that the center hole on their wheels is proprietary and other wheels will not work. Sounds like a bunch of hoop-la to me, but do I #1. Ignore it and find a set of wheels and use my new hubs or #2. Take heed to the advice and buy only RC wheels. They also claim that if they made a wheel for Big Dog, that it would not match the same center hole as their normal wheels. As far as I know, Big Dog is the only company to have ever used RC comp wheels in a factory setting.
    I guess what I need to find out is which bikes came with RC Component wheels. I know the 03 Mastiff did, and I really like those wheels, but finding a used set is going to be hard.
    I want to give a big shout out to you guys. This forum rocks, and so do you folks. Thanks for being accepting of my annoying questions and not kicking me, haha.
    linx
  15. Raywood
    Raywood The Pirate
    Rainbow, CA
    2014 KMW Regulator
    Ray
    Well if you want one for comparison (no measurements) here is LDO's wheel off of his 03 Mastiff after he had them chromed. You can see if looks different then the BDM wheel I posted above.
  16. Raywood
    Raywood The Pirate
    Rainbow, CA
    2014 KMW Regulator
    Ray
    If you are considering putting them on your bike then have you determined if they will fit? What size tire do you have on it now? The 03 Mastiff wheels are 8 1/2" wide for a 240mm tire. This will be a big factor.
    #16 Raywood, Nov 26, 2009
  17. linx
    linx Active Member
    2006 Big Dog K9
    Rob
    Raywood,
    They will fit with a modified swingarm. A 5.5 wide rear will fit with stock swingarm, but I don't mind buying a modified swingarm, or even modifying it myself. It's a really common thing to do for these bikes. 8.5" rear is max I can go, even with the modded swingarm, so really it's perfect. And the 21" front is just icing on the cake.
    That chrome wheel looks wicked man. God I wish I had a big dog. Any company that is cool enough to put something like those wheels on from the factory is a awesome.
    Thanks for everything.
  18. Jeffrey Traylor
    Jeffrey Traylor New Member
    Pompano Fl
    2004 Chopper
    Jeff
    2004 BD Chopper Does anyone know who makes this wheel and what model it is?
  19. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Mad Clown, are what they are called. I believe PM made them. If your needing a new belt pulley, Get when Donna. They had them redesigned, so they are beefier, and Teflon coated.
    PacoPetty and bigkelk9 like this.
