Wheel/Tire Balancing
Discussion in 'Performance' started by Jersey Big Mike, Dec 30, 2015.
  1. Jersey Big Mike
    Jersey Big Mike Well-Known Member
    Full Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    Ok, I know about and have used Dyna Beads in the past and will be putting them in the current new tire, but I was wondering since II discovered that the last tire change even though I requested the beads be transfered that there were no beads when the tire was changed last week.
    This got me to looking for other alternatives and dealers (local) for dyna beads or others.
    During the process I found www.centramatic.com and their permenant balancing system for motorcycles. It mounts a unit behind the rotor that has an active balancing system in it. Now these are more money then the dyna beads but they are install and forget about them and not likely to be "lost" during a tire replacement.
    So my question to the forum is has anyone ever tired these and if so what do you think?
    Mike
    I've mailed them and they say the model mhd 200-202 would be right for my 08 K-9, they also come with a 30 day money back gauruntee from authorized dealers.
    chubs likes this.
  2. KaptinAmerika
    KaptinAmerika Well-Known Member
    Full Member
    2006 Big Dog K9
    Curtis
    Got to wonder what that is going to look like though.
    chubs likes this.
  3. FrankBDPS
    FrankBDPS Well-Known Member
    Full Member
    North Lawrence,Ohio
    Frank
    I had four new tires installed on my Tahoe today. I asked them to install beads instead of wheel weights. They told me they could not do it. I asked why not? You install them in large truck tires. They said the Tahoe tires were too small. When I told them I had beads in my motorcycle tires they said it was not possible and would not work.WTF?
    Bdm4ever and chubs like this.
  4. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I would remove them right away:willynilly:
  5. Th3InfamousI
    Supporting Member Full Member
    Texas
    04 Ridgeback & 07 K9
    They are stuck in the past. That's how the beads stArted for large Truck tires, 18 wheelers originally. I've had them for 8 years in my dodge tho. Never out of balance
    These guys dont understand that centrifugal force is applied across all mediums regardless of size?
    SCOTTx88, dentdude36, chubs and 2 others like this.
  6. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    New tire these days are much closer to being balanced than they were in the 70's when I sold and installed them, back then 7oz. was the limit, and now a days, I haven't seen a tire use more than 3oz.
  7. Nukeranger
    Nukeranger Nukeranger
    Luling, Louisiana
    Huw
    I wouldn't put a centramatic on a bike. I had them on my Dodge truck for years and you could see them through the rims. After they stopped working I went to Walmart BBs and then Dynabeads. Works great for my truck.
  8. kickstart
    kickstart Well-Known Member
    Full Member
    TN
    52 Pan,05 Bulldog, 07 K9
    Pat
    And the BS meter just pegged.
  9. KaptinAmerika
    Full Member
    2006 Big Dog K9
    Curtis
    The stupidity in the world today is just amazing
  10. 429CV23
    429CV23 Member
    Colorado Springs
    2000 Big Dog Bulldog
    Jeff
    I just ordered 2oz of ceramic beads for my new back tire; a whopping $6 shipped.
    I used ceramic/Dyna beads when I put new tires on the motorhome last year (225/70R19.5) and they ride great.
    chubs likes this.
  11. Chillin
    Chillin Active Member
    oVeRtHeRe
    Dyna Beads and forget it........and ride
    SCOTTx88, chubs and BWG56 like this.
  12. SMCT
    SMCT Active Member
    Full Member
    North East
    06 K9, H-D Dyna Wide Glide
    Andy
    The use of beads in an application is "an assumption" and here is why. Beads are calculated based upon the tire. The bigger the tire the more beads. I have dealt with beads as well as dynamic balance and bubble balance as well. My motorcoach, my race cars, the bike. I have had a few sets of tires on my motorcoach (295 80 22.5)and usually use the bead method. The last set of tires I had purchased where so close in the balance, that by adding the recommended amount of beads actually threw it off. no less than 6 miles on the new rubber and I knew something wasn't right. Turned around and went back, and I told them to bust the fronts down and get the beads out, and dynamically balance them. they had the equipment to do so, and I opted for the beads rather than dynamic (cleaner look). After getting the beads out (equal) they only required a few ounces of stick on weights. The coach drove beautifully with it dynamically balanced.
    The race cars. 32 years of racing and the best way to balance is to bubble. The bubble balance is the smoothest ride and we monitor time slips within .003 to .007 as well as mph to 0.25-0.45 at speeds nearing 200mph. Dynamic balancing a drag cars tires is a disaster.
    The only suggestion that I guess I would have, is to see what your up against first, and that means to spin the back tire and see whats going on first before you throw beads into it.
    chubs likes this.
  13. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Bubble balancing when done correctly can't be beat, I have been bubble balancing my tires since the early 70's and I still have the same balancer. I have added a few adapters over the years for 4,5 and 6 lug wheels with a small center opening.
    I have had several people come back and tell me they had their front end aligned after I installed their tires and when the shop found out I bubble balanced the tires, they laughed and put the tires on their new spin balancer to show them how bad bubble balancing was:oldlaugh: guess who was eating crow, they couldn't get it any better than what I had done.
    Old school baby, can't be beat when done properly.:old2:
    pknowles, chubs and dentdude36 like this.
  14. SMCT
    SMCT Active Member
    Full Member
    North East
    Andy
    Borrowed a set of rims and tires at an event in West Palm Beach Florida. Did this going into the 3rd day of racing out of 5 days. Shudder slightly up top with the borrowed rims/tires. Took them off and bubbled them, the bubble was not dead in the center, but favoring the outter line of the circle. First round, broke out. It picked up 1.25mph and .011 in et. I would have been dead on with the slight vibration up top. Nothing like the ride of a bubble that is dead in the center.
    He didn't feel it in his dragster. His had suspension, mine was a hard tail triple slip. when I gave them back, I told him "I fixed your shit"
    chubs likes this.
  15. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Yep, anything inside the circle is good, but nothing beats dead center on the cross hairs:old2:
    Close is only good in horse shoes and grenades:oldhardlaugh:
  16. HMAN
    HMAN Just like to ride
    Ks
    Harry
    And thermonuclear devices.....
    chubs likes this.
  17. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Well that's one thing that the average Joe Shmo can't get his hands on:oldlaugh::old2:
    dentdude36 and chubs like this.
  18. HMAN
    Ks
    Harry
    Who u calling average?
    Viking, chubs and dentdude36 like this.
  19. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Joe Shmo
  20. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :oldhardlaugh::oldhardlaugh:
